Old 04-23-2011, 09:14 AM   #1
thebabybrahma
Hood latch problem
When I trip the latch for the hood release on my 72, it trips but the hood will not "jump" up enough so that I can get a hand under it to lift it up. Matter of fact it doesn't "jump" at all.
It has new hood spring and brackets on the rear of the hood.
Any ideas??????
'85 C-10, with 93 LT-1 & 4L60
1985 GMC, lookin' for its big block motor - SOLD
'72 Chevy C-10 Cheyenne-SOLD
thebabybrahma is offline   Reply With Quote
Old 04-23-2011, 09:30 AM   #2
67Slider
67Slider's Avatar
Re: Hood latch problem
I had a similar problem with my 67. When I took the latch mechanism off I could tell the little sliding piece that locks the hood in was bent and was not allowing the hood to pop out. I had to beat it with a hammer to get it back in shape. Not sure if that is your problem but it sounds like it's hanging up on something.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 04-23-2011, 09:43 AM   #3
cdowns
cdowns's Avatar
spray to heck out of latch with wd40 to clean then put white grease on to lubricate the mechanism
Old 04-24-2011, 07:12 AM   #4
OhioDan
OhioDan's Avatar
Thumbs up Re: Hood latch problem
Sounds like ya need to adjust yer hood hinges. My GMC used to do that, till I re-adjusted them. Now it pops up just fine. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 04-24-2011, 07:58 AM   #5
thebabybrahma
How might one adjust the hinges?
Old 04-24-2011, 08:38 AM   #6
Rob H.
Rob H.'s Avatar
I'm subscribing to this one. I have the same problem on my 72. I was attributing mine to the dent in the outer grille, but after straigtening it some the problem is still there. My 67 pops right up.
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline   Reply With Quote
Old 04-24-2011, 08:55 PM   #7
OhioDan
OhioDan's Avatar
I just loosened my hinges and rotated them to the rear. Raised the front enough to cause the front lip of the hood to pop up a little so you can get yer fingers under it to raise the hood.
Old 04-24-2011, 10:07 PM   #8
racer57
racer57's Avatar
Subscibed
racer57 is offline   Reply With Quote
Old 04-25-2011, 08:55 AM   #9
bigsnookmaster
bigsnookmaster's Avatar
After the cleaning and lubing of the latch, you might want to try adjusting the latch. You can loosen the hood latch part and move it around, and this might help your problem. Good luck
bigsnookmaster is offline   Reply With Quote
