Closed Thread
Old 04-24-2011, 05:15 PM   #2176
mdaven@aol.com
Re: What did you do to your truck today!
Installed a tilt steering column. Discovered some wiring issues from PO. Ordered a turn signal kit to get them working. Need to purchase some electrical connectors to begin the corrective actions. Deciding between the 68 steering wheel and the 70 steering wheel.
mdaven@aol.com is offline
Old 04-24-2011, 07:55 PM   #2177
Sicklajoie
The Niner
Sicklajoie's Avatar
Finally found me some rims that will take the dogdish hubcaps!
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline
Old 04-24-2011, 09:20 PM   #2178
fast50ranger
fast50ranger's Avatar
Talking Re: What did you do to your truck today!
Finished priming my truck with the Finish 1 system by Sherwin Williams and putting on my new wheels.
Big Block Powered
fast50ranger is offline
Old 04-24-2011, 09:53 PM   #2179
gonnuts
gonnuts's Avatar
I finally got my 408 in broke in cam and drove it around a little then pulled my old headers back off, changed the motor mount that the PO hacked up with a cutting torch, and put on new headers. It's going in for new exhaust tomorrow. Can't wait, I'm like a kid with a new toy! I tried adding pics but it wouldn't let me, said I was missing a security token???
gonnuts is offline
Old 04-24-2011, 11:01 PM   #2180
mightymouse
mightymouse's Avatar
i had the exact problem back when i tried to post pics . i just had to down-size pic size.........mighty-mouse
mightymouse is offline
Old 04-24-2011, 11:19 PM   #2181
Keller
Keller's Avatar
got my transmission upshift issue figured out.. the vacuum line just came disconnected from the modulator on the tranny when i was pulling the points out and dropping in the HEI.
played around with the timing a bit and holy crap did HEI make a difference! no more hesistation when i floor it and the tires scream all the way through first gear!
1972 C10 Longbed 350/350
Keller is offline
Old 04-24-2011, 11:24 PM   #2182
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I cut the metal plates to use as filler panels for the door handles when I shave them.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 04-24-2011, 11:57 PM   #2183
ItsRandy
ItsRandy's Avatar
Wow!!! Really, really nice truck!
ItsRandy is offline
Old 04-25-2011, 12:02 AM   #2184
Jeffs70
Jeffs70's Avatar
got me a set of air bags and went out for about an hour after the easter party to get an idea of how I will mount them in my truck.
Jeffs70 is offline
Old 04-25-2011, 12:03 AM   #2185
orange70350
orange70350's Avatar
I picked up my frame form getting blasted and painted
orange70350 is offline
Old 04-25-2011, 01:49 AM   #2186
project 67 sub
project 67 sub's Avatar
found out i need a new light switch
project 67 sub is offline
Old 04-25-2011, 10:41 AM   #2187
DT1
DT1's Avatar
I just got my AC converted to R134A. New expansion valve, poppet and drier.
It was almost $500.00 but here in the desert, it's a must!
DT1 is offline
Old 04-25-2011, 10:49 AM   #2188
72rookie
72rookie's Avatar
I discovered that I have a cracked exhaust manifold! So this time next week I will be posting that I replaced my cracked exhaust manifold (hopefully)!
72rookie is offline
Old 04-25-2011, 11:55 AM   #2189
DorianB
DorianB's Avatar
Tracked down a transmission leak to where the spedo cable connects. Adjusted and replaced lost hardware on my new step side bed.
DorianB is offline
Old 04-25-2011, 01:53 PM   #2190
6772owner
Gearhead
6772owner's Avatar
I finally received my ECE trans crossmember for the 72' as well as a new 3/8" sender and defroster vent for the 67' Hopefully both trucks will that much closer to completed after this round of parts.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline
Old 04-25-2011, 11:03 PM   #2191
FRENCHBLUE72
PROJECT 7DEUCE
Worked on my tailight fuel fill and finally shaved the passenger door..
MEMBER #6377
Project "7DEUCE"
Old 04-25-2011, 11:08 PM   #2192
wwotr
wwotr's Avatar
DT1,
Where in the "Desert of California"?
I'm in Palm Desert, (15 Miles East of Palm Springs) in the Coachella Valley.
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline
Old 04-25-2011, 11:09 PM   #2193
70cst
70cst's Avatar
Today I had the correct front springs installed plus the rear TT Wheels were installed on the rear.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline
Old 04-25-2011, 11:21 PM   #2194
gonnuts
gonnuts's Avatar
Got my exhaust put on, they did a nice job sounds sweet @ lower rpms, has a bit of a bark to it above 3. Didn't feel like jacking it up so I could get underneath to take pics so here's a couple of how I had tail pipes routed. http://67-72chevytrucks.com/vboard/a...1&d=1303787789
gonnuts is offline
Old 04-26-2011, 12:08 AM   #2195
Jeffs70
Jeffs70's Avatar
got the top plate and bottom cup made for my passenger side front air bag and got it mocked up and installed to test fit it. works out perfect to my liking
Jeffs70 is offline
Old 04-26-2011, 01:10 AM   #2196
DaBigKahuna
DaBigKahuna's Avatar
Got my Truck registered in the Peoples Republic of California which actually took most of my day off!
DaBigKahuna is offline
Old 04-26-2011, 07:07 PM   #2197
PatrickGMC70
PatrickGMC70's Avatar
Seems fitting...
PatrickGMC70 is offline
Old 04-26-2011, 07:43 PM   #2198
DaBigKahuna
Originally Posted by PatrickGMC70 View Post
Yeah... that's about the size of it!
Old 04-26-2011, 08:30 PM   #2199
sjarrett71
sjarrett71's Avatar
Fixed a wire splice that the PO used a wire nut on. Also took out my license plate lights and fixed a few of the broken wires for them. And I installed my fan shroud.
-Scott-
sjarrett71 is offline
Old 04-26-2011, 10:36 PM   #2200
Rudy67chevy
rudy67chevy
Rudy67chevy's Avatar
I replaced my 350/th350 with a 350 crate engine. And 700 R4. Here are before and after pics.Name:  picsay-1303868101.jpg
Rudy67chevy is offline
Closed Thread
