Old 04-16-2011, 09:26 AM   #376
silvertip67
silvertip67's Avatar
Re: post your 67-72 4x4
you can definetely see how the axles are aligned more properly in the wheel wells...chassis and drive train were tweaked really well...
ted cruisin in my '67
K-20 '67 Custom Sport Truck
'55 Chevrolet 3100 w/ 235 il6(Powermaster)
'63 Chevrolet 1/2 ton 250 il6
'65 Chevrolet 1/2 ton 283 V8
silvertip67 is offline   Reply With Quote
Old 04-18-2011, 12:39 PM   #377
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by silvertip67 View Post
Stock 4x4's are so rare around here I never noticed the wheel placement problem.
I put them where they looked right when I set up my 67 4x4 conversion.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 04-21-2011, 10:49 PM   #378
silvertip67
I am not a real expert in matters like tire sizes etc...I did a slight suspension lift ...as mentioned before...I have 235 X16" on the truck now(as pictured)...how big can I go?? 265 or 285's??
just looking for a bigger tire to ride on the beach...and of course a bit cooler ride/look...well at least I am honest...LOL...walmart has the goodyears (ATV) in those sizes...and there is a wal mart about 25 miles from here...about 800 bucks for a set...what do you think???
Old 04-22-2011, 11:19 AM   #379
68 TT
68 TT's Avatar
I like the tread on the Walmart Goodyear Wrangler Authority tires and they have a 265/75-16 load range E tire available for $189 plus install. It is what I will be putting on my 67 when I get to that point.
It should fit your truck with the lift you have. It will be just under 32" tall. The tires on my 67 in the above pic are 32x11.50-15's for reference.
Old 04-22-2011, 06:19 PM   #380
silvertip67
thats the same tread I was talking about...and the price is good too!
thanks for the reply...
Old 04-22-2011, 09:52 PM   #381
glimmertwin01
glimmertwin01's Avatar
285's might work.... they are like a 33
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 04-22-2011, 10:54 PM   #382
NEVERENOUGH
NEVERENOUGH's Avatar
I run a 255x85x16 on my dually it is a narrow 33 would look really good on a stock type wheel.
NEVERENOUGH is offline   Reply With Quote
Old 04-23-2011, 10:05 PM   #383
1972RedNeck
1972RedNeck's Avatar
Here's mine.
1972RedNeck is offline   Reply With Quote
Old 04-23-2011, 11:09 PM   #384
silvertip67
like that elk proof bumper!
Old 04-25-2011, 03:35 PM   #385
RatRod68
RatRod68's Avatar
^^This truck is sex on wheels.
Here are a couple of my 71
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 04-25-2011, 03:36 PM   #386
RatRod68
RatRod68's Avatar
sorry. Double Post
build Threads:
Leftovers 68 C20
Semper Fi
Old 04-25-2011, 03:54 PM   #387
silvertip67
nice truck...my wife wants me to get a pair of those stirrups so she can get in easier...what kind of shock is that going across the front end??
Old 04-25-2011, 04:02 PM   #388
RatRod68
RatRod68's Avatar
no clue. i bought it pretty much like this. i just added the grille and lights
build Threads:
Leftovers 68 C20
Semper Fi
Old 04-27-2011, 12:13 PM   #389
silvertip67
fixing rear cab mounts
I have two rubber mounts that are shot( the rear ones under the seat) I made up some solid rubber "hockey pucks" to put in the place of the sag...and ideas out there on removing the nut/bolt that holds them in place...
have dosed the spots up good w/ liquid wrench...anyone out there fixed this before...any have a heads up on any possible problems...thanks...t
ones side droops about 1 " the other maybe 3/4"...probably not a big deal...but it does drive me crazy...
Old 04-27-2011, 11:04 PM   #390
wiggins
wiggins's Avatar
Yaeh back when I was in college (ie broke) I made some by cutiing up litttle squares out of an old tire and they worked good to level everything backout. I am from texas so I have never touched a Hockey puck but it sounds like a goood fix as long as its not to hard (stiff). As far as the botls you will have to have a back up inside the cab and you may have to remove your seat. May try an impact wrench 1st just to see if it would bust then off before taking you seat out but I doubt it will. Probably a good time to go ahead and replace the bolts and nuts as well. I always use grade 8 bolts for this.
Preserving American History one truck at a time.
wiggins is offline   Reply With Quote
Old 04-28-2011, 08:32 AM   #391
silvertip67
thanks for the info...I was trying to avoid taking out the seat...will do as you suggested...am I to understand that the threads are not a stud? but goes through the lower cab? w/ a nut underneath...so a box wrench or similar has to be attached under the seat ( to hold bolt)to get it loose if an impact alone does not work on the lower nut?
I have looked at drawings in the LMC catalog and its not that clear how it is attached...
thanks again...t
Old 05-20-2011, 12:06 PM   #392
L8brake731
L8brake731's Avatar
Noticed you have after market head lights. How do you like them? Thinking of those and mods to HID....
L8brake731 is offline   Reply With Quote
Old 05-21-2011, 01:15 AM   #393
RatRod68
RatRod68's Avatar
That are amazing. I have them in both my C10s
build Threads:
Leftovers 68 C20
Semper Fi
Old 07-25-2011, 08:36 PM   #394
plummen
Originally Posted by Mudder View Post
Some old pics from photo shoots.
wow ive never been much of a stepside fan,but i might have to rethink that!
nice truck!
plummen is offline   Reply With Quote
Old 07-26-2011, 11:52 PM   #395
68 TT
68 TT's Avatar
thanks again...t
The rear cab mount fasteners are just a 6" long bolt that comes in from the bottom on a 1/2-ton. A little longer on a 3/4-ton but still comes in from the bottom the same way. The nut is captive and up in the body and does not need to be accessed at all to get the rear cab mounts out.
Old 07-27-2011, 02:37 PM   #396
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Unless you live around here and have to cut the nut off to get the bolt out to get the cab off. Thank you rust.
Ryan
1969 Chevy milk truck
Old 07-27-2011, 04:59 PM   #397
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Even on my gmc (central texas truck) the bolt was froze in the nut witch spun around in the retainer. It was just a bad design.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 07-27-2011, 06:45 PM   #398
68 TT
68 TT's Avatar
Hadn't thought about that. None of the trucks I have had were rusty in that area. Guess I have been lucky.
It is definitely a poor design. I guess you could convert it to a thru bolt design like the front cab mount if it twists in place or breaks off.
Old 07-27-2011, 07:45 PM   #399
Dieselwrencher
Well at least they aren't like the 73-87's. You have to cut the floor of the cab to access the nut whet it spins in the retainer.
Ryan
Old 07-27-2011, 08:11 PM   #400
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I just cut a little hole in the rear cab support right behind the nut with a cutoff tool then welded it solid.
Tony
