07-19-2003, 04:25 PM | #1 |
Short or Long Water Pump?
Could anyone help?
On a small block, I'm going with electric fans and eventually an Old Air system, but for now it's just the p/s and the alternator that I have to run. Would I need a new p/s bracket and alternator bracket if I switch to long water pump? I have a newer large damper. Will that cause a conflict? |
07-19-2003, 06:02 PM | #2 |
Glowing since 1978
Old Air recommends keeping the stock mechanical fan with clutch and a shroud for their units. The best location for the alternator and p/s pump is drivers side. Makes for a cleaner A/C compressor install. I don't know about the conversion to long pump though but do know that they need to know short or long pump when ordering the A/C unit for the pulleys to line up. I'm pretty sure the brackets for the p/s and alternator need changed do to the pulley location changing. Since I believe cars with 350 from the mid 70's on had long pumps the brackets should be available readily in the junk yard.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
07-21-2003, 05:39 AM | #3 |
user # 2756
I think the brackets will need to be changed. Our trucks came with the short pump w/ the PS brackets mounted to the block and engine mount. with a long pump the PS bracket is mounted w/ the wp and block. The long pumps deput in late 60s in the GM cars and trucks in 73 I believe. Except w/ vettes.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
07-21-2003, 07:12 AM | #4 |
The brackets will need to be changed if switching to a long neck water pump as will crank & water pump pulleys. The larger 8" harmonic balancer will not affect choice of water pumps or pulleys.
GMCPaul |
