best fitting headers, 4x4 4spd
need opinons on headers. built a new 400 sb, vortec heads, erson cam,9to1 compression. have corvette ramshorns and 21/2inch dual into single 70 series 3inch flowmaster. very quiet and not as much power as i had hoped. wandering-wanting to go the header route and change to 2 magnaflow mufflers. any power difference? what is the best fitting header for a 4x4 ,4spd truck. please help
1972 3/4 4x4,14bolt locker rear, dana44 lock right front, sm465, sb 400, blazer tank,dual batterys,3"lift,32-9.00-16 super swampers daily driver other trucks 1972 1 ton dually 4x4,454 4 spd,,235-85-16, flat bed front and rear winches, rear gas tank and under bed gun safe.tilt wheel |
go cyclones
I have no personal expericnce but reader a thread a while back the dynomax cermic coated headers got good reviews. they are about 230 bucks at jegs or summit.
btt
The Dynomax headers mentioned above will not work on a 4 speed, I just found out the hard way this weekend. I wish they would fit, I would love to swap you for those manifolds.....
![]() Join Date: Feb 2002
I have Heddman Hedders on a crate 350 in my '71 GMC Jimmy, w/SM465.
The Heddmans fit OK, but are a little close around the starter. To replace it, you have to pull the Pass side hedder. I had to reconfigure the Z/bar on the driver's side to clear the collector down tubes, but that might have been due to the different throw-out geometry for a Centerforce II clutch. I was on a budget at the time I got this truck back on the road and the Heddman's were on sale. It's been a daily driver for 4 years. ![]()
user # 2756
![]() Join Date: Jun 2001
I read somewhere that the tri-ys from doug Thourley (sp) fit around the z-bar and were made for our trucks. Pricey though close to $400.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
![]() Join Date: Aug 2001
I went with the Ceramic Coated Hedman. It is the only one that fit on my truck. Had to have Summit order them special. I tried the Elite set from Hedman but they would not clear the linkage on the 4x4 4speed 350
