04-26-2011, 09:57 AM | #1 |
will 3/5 CPP drop kit work for me?
Can anyone tell me if aCPP 3/5 drop kit will work on a 1968 without doing any other modifications? What about C notch I keep hearing about? Truck has front disc and rear drum. thanks
04-26-2011, 10:00 AM | #2 |
Re: will 3/5 CPP drop kit work for me?
kit should work just fine, no c-notch needed with a 5" drop. There are a lot of members running that same exact drop with no problems.
04-26-2011, 10:12 AM | #3 |
Just a car guy
I recently installed the 3" front, replacing my cut stockers. It actually raised mine some. It looks low and is almost touching the bumpstops on my lower a arms, which are off a 1975.
I am probably going to cut 1/2 coil off these to get the look I want. Got to see the rears first. I am in the process of swapping the 5" into the rear on mine as well. Replacing stockers that I assume were heated. Looks like it will sit about the same in rear, which makes me think I may add a 1" block. Posted via Mobile Device
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
04-26-2011, 10:20 AM | #4 |
Just a car guy
Edit! This is with stock cut fronts and heated rears. Stock 235/75/15 tires
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig Last edited by OJ1988; 04-26-2011 at 10:25 AM. Reason: Wrong info |
04-26-2011, 10:22 AM | #5 |
Just a car guy
With 3" ccp fronts and stock heated rears, With 235/60/17s
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig Last edited by OJ1988; 04-26-2011 at 10:27 AM. |
04-26-2011, 10:58 AM | #6 |
Moderator
you will not need a c-notch with a cpp 5" rear drop spring. i have cpp 5" rear springs, along with 1.5" blocks. i just finished installing a c-notch in mine, as it was needed at that point. you will have about 3" of clearance running just the drop springs. you will need to remove the factory bumpstops.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
04-27-2011, 01:16 PM | #7 |
ya the back is easy..no C notch is needed unless you want the frame on the ground........the front gets to be a headache with the drop spindle that has to have the disc brake upgrade. you can cut the spring down and run it...i did this for years but it wears out the outter inche of the tire.... If you want to put airbags you have to put in the 2.5 drop spindle and disc brakes....and then the stock rims don't fit so you need to get 18's or 20's.....seems to never end. Do it right the first time....get the front disc brake kit, and ball joints, tie rod ends if you need new ones....the 2.5 drop spindle, the rev 7 air bag kit from SDoors, and 20 inche rims....
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
