Old 07-20-2003, 07:18 AM   #1
treefrog
One more wheel well ? 3 part
Got the inner wells out.
1. How do you get that @#$%& undercoat type paint off?
Impossible to keep clean.
2. Why even go back with it?
3. While they're out, go back on the engine side with S-gloss
black or body color?
Thanks for your input. Almost done. TF
treefrog is offline   Reply With Quote
Old 07-20-2003, 01:24 PM   #2
BIG ORANGE
BIG ORANGE's Avatar
TF the undercoat pertects the underside of the fender from rocks being thrown up and denting the innerfender and rusting out, with your truck being mostly stock it would be in your best interest to paint the topsides of the inner fenders semi gloss black to keep the factory theme going strong,and you could alway redo the under coat by spraying over the top of what already there. Hope this helps!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 07-20-2003, 01:28 PM   #3
weasel29gm
SLOW BUT SURE,BUT CLOSER
TF, udercoat is hard to get off by hand, use air and wheel then prime and paint. On underside gloss black, motor side semi- gloss.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 07-20-2003, 01:31 PM   #4
weasel29gm
BTW, I just painted over mine on the underside, I agree with BO, use it on a driver.
Old 07-20-2003, 05:57 PM   #5
Yep...I cleaned mine best I could with wire wheel, then recoated the underside with spray-in bed liner. So far seems to hold and and looks good too.
Old 07-21-2003, 12:08 PM   #6
treefrog
Many Thanks. Black it is on the wheel wells. I just hope someday can get enough experience to be of some help to you all.
Treefrog
Old 07-21-2003, 12:48 PM   #7
Just will me your truck!
Old 07-21-2003, 02:03 PM   #8
treefrog
Last Will
Palf,
I'll consider the possibility. My kid would just sell it anyway.
TF
Old 07-21-2003, 02:32 PM   #9
Shane
Shane's Avatar
not the safest method out there, but kerosene will soften the undercoating up, and you can then use a plastic scraper.
Shane is offline   Reply With Quote
