Old 07-21-2003, 01:10 PM   #1
tyger25
tyger25's Avatar
Guage questions.
I just installed new Autometer Phantom guages, and have a couple of questions.
What should I put in the hole the factory tach came out of?
What is a good engine ground for the voltmeter?
How do you ground the Fuel Guage?
Where is the coil to connect the Tach?
Thanks for any help!
U.S.A.F.
68' C-10 Stepside
305 w/ 4 speed
tyger25 is offline   Reply With Quote
Old 07-21-2003, 01:22 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Radar, sonar, or depth finder? How about a game of "Pong"? (If you don't know what this is you're too young, so don't ask)?
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 07-21-2003, 03:16 PM   #3
racedvl
racedvl's Avatar
Here's my set up.
racedvl is offline   Reply With Quote
Old 07-21-2003, 06:59 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Tach hole...good place for a tach. No need for a huge monster one to fill one of the big holes IMO, the best location is where the stock one was, direct line of sight.
'Engine ground' is a BS term for ground. Your dash should be grounded, as is your inst panel. If the inst panel isn't grounded well, run a wire from the backing plate of the inst panel and secure it to the dash. (I recomend doing that even if you DO have a good ground)
Coil to tach... If you have the original points set up, run a wire from the neg terminal on the coil and hook it to the green wire on you (asumed) aftermarket tach. If you have the HEI upgrade, then run a wire from the TACH terminal (next to the 12 volt input) and run it to said green wire.
Fuel guage...I can't help you on that...onless it is an OEM guage.
Old 07-21-2003, 07:46 PM   #5
oldtrucknut
67-72 truck surgeon
I did the exact same thing with my instrument panel. I took a piece of plexi glass and scuffed it with 1400 grit sand paper, then painted it with white spray paint to match the guage faces. Don't laugh, it looks good... I used super glue sparingly to fasten it to the back side of the bezel. I mounted it with the smooth, non painted side out. It doesn't have to be cut perfect, as you have a little room to play with. I also used small colored light assemblies for turn signal indicators that slid through the factory bezel and hold the plexi glass in place. If I had a digital camera I would be happy to take a picture for you. The fuel level guage can be grounded anywhere.
1969 Chevy C10
1993 Toyota Camry LE
1999 Ford F250 Super Duty 4x4 diesel
2008 Dodge Charger Super Bee
1953 International R182
oldtrucknut is offline   Reply With Quote
Old 07-21-2003, 10:48 PM   #6
Michael12
Were the stock tac was you should replace it with a clock and have your tac were the gas guage was and have one of the small gauges on the bottom be the gas guage. and you still have 3 guages for your volts, oil temp, and water temp.
Good luck with everything...
-Michael
Michael12 is offline   Reply With Quote
Old 07-21-2003, 11:12 PM   #7
tyger25
tyger25's Avatar
-Michael
That's pretty much what I did. Big Speedo, and big Tach. Small fuel, water temp, oil pressure, and voltmeter. I just got to get them all to work now! Thanks for the info!
U.S.A.F.
68' C-10 Stepside
305 w/ 4 speed
Old 07-22-2003, 02:32 AM   #8
hjalbert
cracker
hjalbert's Avatar
hmm
well, anythign the other guys said would go great, but if you decide to sell your factory tach and harness and all (if you had one) let me know thanks
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Harry John Albert III
located in Phoenix, AZ
1972 GMC JIMMY,
1969 lwb Chevy Frame,
1999 bmw k1200 ltc
1992 Kawasaki concours
1991 bmw k75
1973 cortez motorhome
hjalbert is offline   Reply With Quote
Old 07-22-2003, 10:37 AM   #9
Ackattack
Ackattack's Avatar
Here's a pic of my guage setup. I'm using the center area for my dummy lights and high beam indicator (since I'll be getting the matching speedo soon).
I used a terminal block (I think that's what they call it) to wire from the guages to the cluster, and then from the terminal block to two 6 wire trailer harnesses so that if I have to remove the guages, I just unplug the harnesses and it pops out (have to disconnect headlight, wiper switches and speedo cable too). I used the opposite ends of the trailer harness so that I can't mix them up and run everything messed up.
Ackattack is offline   Reply With Quote
Old 07-22-2003, 12:55 PM   #10
tyger25
tyger25's Avatar
Trailer harness! I never thought of that! I did think of some type of connector, but couldn't find one that helped any.
U.S.A.F.
68' C-10 Stepside
305 w/ 4 speed
Old 07-22-2003, 04:03 PM   #11
Longhorn Man
That is a pretty good idea.
