Old 07-18-2003, 03:36 PM   #1
Lobo'74
Lobo'74's Avatar
'67 C-10 back window
I found a '67 C-10 I'm interested in with a rebuilt high performance 350. Its even been recently repainted exactly the color I would have chosen . Down side is that it has the small back window and I really like the big back window. Any easy way to retrofit the large window on a '67, or is it a hassle involving a donor cab and large amounts of body shop time and dollars?
Thanks for any info.
Lobo'74 is offline   Reply With Quote
Old 07-18-2003, 03:49 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Buy it and drive it like it is or buy something else.
Making the small window in to the big window via grafting from a donor would be a big time pain, plus you'd end up repainting (read major $$$). To do that to a small window 67 would be foolish especially since there are many trucks out there and the majority are the large window variety. At the very least it would be easier to swap cabs IMO.
I trade a large window cab for a small window cab of equal shape in a heartbeat, they look the best to me.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 07-18-2003, 03:50 PM   #3
GasHog396
Ewwww. That's an ugly thought. It would probably involve a donor vehicle, cutting wheel, MIG welder, grinder, maybe some Bondo and a lot of measuring. The fit would have to be perfect to prevent leaks, and then you would have to have it repainted. I personally would just live with the small window. There are a lot of big window trucks out there, the small windows are kind of unique
'67 1/2 Ton Short Bed / 396 cid / AC w-R134a / 5 Lug Leaf spring rear axel / 5 Lug Frt Disk Brake Conversion
'97 Trans Am - Black / LT-1 / K&N FIPK Cold Air Kit / Hooker Cat-Back Exhaust / 160 Thermostat
'02 Buick Regal GS / Bone Stock
GasHog396 is offline   Reply With Quote
Old 07-18-2003, 03:52 PM   #4
jef5150
Inline 69
jef5150's Avatar
Thumbs up small window
ditto,,,,,,id rather have the small window,,arent they harder to find???/
jef5150 is offline   Reply With Quote
Old 07-18-2003, 03:54 PM   #5
Lobo'74
Lobo'74's Avatar
Thanks for the info y'all. What you are telling me is what I thought too. Drive it as it is. Truck seems in GREAT shape, so looks like if I get it I'll learn to love a small back window.
Old 07-18-2003, 03:54 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
Yep, only made them in 67. Another reason why 67's are the best!
Old 07-18-2003, 04:03 PM   #7
1971 Cheyenne
1971 Cheyenne's Avatar
I think small windowz really grow on you. When I was looking for a truck, I wanted anything that wasn't a small window- I HATED THEM. Right now though I would trade my cab anyday for a small window. Kind of like the color Ochre It grows on you
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 07-18-2003, 04:17 PM   #8
72c10step
WHYBYNU when old will do?
72c10step's Avatar
I'd much rather have a small window as well. A friend of mine picked up an all original 42,000 mile 67 with the small window, and I keep getting him to try to give it up, but he loves it too much.
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 07-18-2003, 04:25 PM   #9
GasHog396
The only downside to a small window, as I see it, is you can't replace it with a sliding window. At least I've never seen a small sliding rear window. My '67 has the large rear window (sliding), but it's hard to tell what year the cab is. The VIN tag says '67, but it has been taken off at least once, that I know of, to acid dip the cab (long before I bought it). Oh well, the state says everthing is legit. I really doubt there are two parts on my truck that left the factory together.
Old 07-18-2003, 05:25 PM   #10
da-burb
"Ochre Ogre"
da-burb's Avatar
They did make a small window slider insert. I doubt it was made by GM. I have seen them in several trucks before. I found one in the salvage yard but it was in bad shape. Also, if you think you have a blind spot with the small back window, loose another 50% viewing with all the aluminum trim in a slider.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 07-18-2003, 07:31 PM   #11
GasHog396
Agree with the visibility issue, but you can get some air moving through the cab with that back window open. Helps a lot when the A/C decides to blow warm, like yesterday. Gotta find that leak.
Old 07-20-2003, 02:42 AM   #12
DHregdovic
You can get a slider from GMC Pauls. That's where I got mine from . I was around $110 with shipping included. Not too hard to put in either, I had it tinted 1st though. Allows alot more air to come through...
67 LWB GMC
250 inline w/4spd manual
Disc/power brake conversion
DHregdovic is offline   Reply With Quote
Old 07-20-2003, 11:54 AM   #13
ginter
ginter's Avatar
The coolest thing about the 67 is the small window IMHO.
ginter is offline   Reply With Quote
Old 07-20-2003, 03:18 PM   #14
casey
casey's Avatar
just had a crazy thought, I wonder what cab corner windows would look like on a 67, I'd like to see that, I wonder if one of you computer wizz's could do a pic of that
casey is offline   Reply With Quote
Old 07-21-2003, 04:32 AM   #15
tmad
Man stay wiyh the small window! It make the 67's unique
tmad is offline   Reply With Quote
Old 07-21-2003, 09:21 AM   #16
Randy70C-10
Randy70C-10's Avatar
Damn, if I didn't have so much work into my cab I'd trade ya. The small window cabs are cool.
Randy70C-10 is offline   Reply With Quote
Old 07-21-2003, 09:30 AM   #17
Ron
Ron's Avatar
I restored my 67 just becouse of the small window. Small windows are cool!
'69 SWB
'76 International "Terra"
"Hooked on holiday beer"
Ron is offline   Reply With Quote
Old 07-21-2003, 09:43 AM   #18
Mudder
Mudder's Avatar
I went a looked at a small windwo cab about a month ago and passed on it because it had the small window. Was one of the most rust free trucks I have ever looked at and the guy was only wanting 1000 bucks for the truck and an extra small block.
Mudder is offline   Reply With Quote
Old 07-21-2003, 02:00 PM   #19
krue
Designated A-hole!
krue's Avatar
Don't care for the small window, but Welcome to the board!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
