Old 04-24-2011, 12:21 AM   #1
hammerdog57
hammerdog57's Avatar
55-59 door hinges interchangable?
Are upper and lower hinges interchangable? I thought the only difference was the hold open feature. Will bolt in but out side of hinge seems to be hitting outer hinge pocket not allowing hinge to be adjusted outward. Any thoughts?
hammerdog57 is offline   Reply With Quote
Old 04-24-2011, 01:32 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 55-59 door hinges interchangable?
I remember running into the same thing on my 59. I had the lower in the upper and upper in the lower and couldn't adjust one of them. I have some hinge sets at the shop I'll try to remember to measure them and get back to you.
Old 04-24-2011, 04:59 PM   #3
hammerdog57
I was mocking up door door using two upper hinges. (all i had to use) Problem is door closes but needs to come out at the bottom. There is room in caged nut slot to do this but cant because hinge is hitting outer hinge pocket skin. Lower door hinge is also hinge binding on hinge mounting plate. If hinge could move out door would fit nice.
Old 04-24-2011, 11:27 PM   #4
chevyrestoguy
chevyrestoguy's Avatar
I'm having the exact same problem with mine. Hits the pocket on the driver's side lower hinge. I got so disgusted with it, I moved on to other stuff on the truck.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 04-28-2011, 07:47 AM   #5
bondobob
bondobob's Avatar
I had the same problem with my upper drivers side. I couldn't get the door to move out far enough to line up with the "A" pillar. I finally milled off 1/4" on the inside surface of the hinge and welded a 1/4" plate to the outside (this is on the section that goes into the door). Re-drilled the holes and did some filling. Now the door is flush and the hinge adjustment is in the middle. Sorry I don't have any pictures of the job.
bondobob is offline   Reply With Quote
Old 04-28-2011, 02:20 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
I looked at the hinges I have and the only difference is the lower has a nut welded on the inside and the upper has the piece to hold it open.
