Old 04-27-2011, 11:38 PM   #2451
daverod
SSN 706
daverod's Avatar
Re: Daverods project 66
Yes I got one fron Capt.
daverod is offline   Reply With Quote
Old 04-27-2011, 11:46 PM   #2452
Strodder
Daring to be Different
Strodder's Avatar
Did it look like this?
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 04-27-2011, 11:50 PM   #2453
Strodder
Strodder's Avatar
Can't post picture?? Still learning my droid x
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-27-2011, 11:52 PM   #2454
daverod
SSN 706
daverod's Avatar
I think the problem is because I pancaked my crossmember. It raised my arms up 1 1/2".
Old 04-28-2011, 12:54 AM   #2455
watahyahknow
watahyahknow's Avatar
you might need to add 2 extra joints in the steering now
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 04-28-2011, 01:28 AM   #2456
Captainfab
60-66 Nut
Yep, that is why. I didn't stop to think that would be a problem. Is the upper arm hitting the steering shaft hard, or just a little?
Old 04-28-2011, 03:11 AM   #2457
watahyahknow
in other words if you can put a notch in the upper arm or change it to a tubular arm to clear the steering
Old 04-28-2011, 09:33 AM   #2458
daverod
SSN 706
daverod's Avatar
Seems to be hitting it hard. I have'nt really mounted the steering column. I really don't want tube arms. I was looking for some pictures of how guys added a couple links. Could find any. I know I've seen some. I think they were for doing R&P though. Not to many people with pancaked stuff. I would say the shaft hits into the arm about 3/4 to an 1".
Old 04-28-2011, 09:54 AM   #2459
daverod
SSN 706
daverod's Avatar
OK maybe it hit more. It would be a big notch.At full up it touches. Last few are full down. Maybe a notch and a link? There does'nt seem to be a lot of room. Maybe zig it over to above the frame then back? or zig it up?
Old 04-28-2011, 10:02 AM   #2460
Strodder
Strodder's Avatar
Looks like you will have to do something like this. I'm a Borgenson Dealer if you need anything.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-28-2011, 10:10 AM   #2461
daverod
SSN 706
daverod's Avatar
2 ujoints and a support bearing should do it.and a coupler. Pm me a price. No rush. or what ever you think I need. I knew I was being nice to you for a reason.
Old 04-28-2011, 10:55 AM   #2462
Strodder
Strodder's Avatar
Bite me. You have PM
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-28-2011, 03:10 PM   #2463
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
This is what you need right here. http://www.c10forum.com/forum/showth...ghlight=Jeebus
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-28-2011, 03:11 PM   #2464
daverod
SSN 706
daverod's Avatar
That's it no more mister nice guy. I'm going to be on Americia's funniest videos this Sunday. A minute to win it. Set your DVR. If I win I'll give you $10.
Old 04-28-2011, 03:15 PM   #2465
daverod
SSN 706
daverod's Avatar
Originally Posted by ruffrida2005 View Post
Looks like $$$$
Old 04-28-2011, 03:27 PM   #2466
ruffrida2005
There only $199 I think for the uppers, powder coated with ball joints for right now.
Paul
Old 04-28-2011, 06:00 PM   #2467
watahyahknow
those a arms look nice .......... wat you could try is raise the steeringbox using a realy thick and strong adapterplate that bolts intoo the original boldholes of the chassis and has studs to mount the box higher up doing it that way alows you to return to stock if this doesnt work .
it might even correct the steering geometry as you allready raised everything up the chassis that comes after the steeringbox ...... that is as long as the steeringrods and stuff comming of the box still clears the underside of the chassis after the raising
Old 04-28-2011, 06:13 PM   #2468
SCOTI
SCOTI's Avatar
You can use a smaller diameter shaft & gain some clearance. That tube over shaft collapsible arrangement can be swapped for a 3/4" shaft. You'll still have to also raise it up slightly w/a support bearing & some u-joints w/the 1.5" notched x-member.
With my 1 1/8" notched/sectioned/pancaked x-member using OE arms, I cleared w/the smaller dia shaft (standard aftermarket 3/4" DD shaft). It only made contact w/zero air pressure.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-28-2011, 06:46 PM   #2469
ruffrida2005
I say go with the MMW arms I posted. They will look cool as hell. I have his uppers for my s10.
Paul
Old 04-28-2011, 06:51 PM   #2470
daverod
SSN 706
daverod's Avatar
Their web site doesn't work. Cant you get those arms w/ a stock ball joint?
Old 04-28-2011, 07:26 PM   #2471
ruffrida2005
give his company a call, And yes you can get them with stock ball joints. He is rebuilding his site so that's why it's messed up.
Paul
Old 04-30-2011, 03:19 PM   #2472
daverod
SSN 706
daverod's Avatar
Got my $hit jack up last night. Raised everything 1". Everything clears. Well except for the steering shaft. Dont know ? Can I just cut the shaft to make it shorter or does it need splines in the end. The way it is now I don't think I have enough room to move it much.
Old 04-30-2011, 06:52 PM   #2473
Strodder
Strodder's Avatar
Hey Dave your idler arm should be the same angle as your pitman arm. Your going to be all jacked up.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 05-01-2011, 12:53 AM   #2474
daverod
SSN 706
daverod's Avatar
How do you know I did'nt raise it too.
Old 05-02-2011, 01:21 PM   #2475
Strodder
Strodder's Avatar
I was just looking out for you. People need to know that. So stop being so lazy and post more pictures of everything you do. Or should I say almost everything you do. Some things should be kept to yourself.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
