Old 04-27-2011, 11:55 PM   #1
Ackattack
Ackattack's Avatar
U joints questions
I searched and couldn't find my answer.
Is the stock u-joint for a 69 3/4 GMC 4 speed/dana 60 a 1350 u-joint? Pretty sure it is, just double checking?
Second question:
What u-joint was used in 73+ 12 bolt rear ends? I'm not sure if the rear end I have is out of a 2wd or 4wd or what exactly. All I know is that it is a 12 bolt and does not have the ear on the pumpkin for the panhard bar. I assume that it is a 73+ because the front suspension from the same vehicle was 73+ also. So I figure someone at some point swapped this in from the same donor vehicle. The u-joint appears to be a 1330 series or something very close...but the u-joint doesn't seat completly. It's been awhile since I looked at it....so I'm doing some preliminary research.
Ackattack is offline   Reply With Quote
Old 04-28-2011, 12:01 AM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: U joints questions
my 67 and 76 12 bolts are both 1310. You gotta look out for those 1330 and 1310 big cup ujoints used on some ford stuff.
brad_man_72 is offline   Reply With Quote
Old 04-28-2011, 08:02 AM   #3
Jessechop
The 69 3/4 ton is a 1350
The 73 up is a 1310
TON of info here http://www.neapco.com/pdf/2007universaljointcatalog.pdf
Jessechop is offline   Reply With Quote
Old 04-28-2011, 08:30 AM   #4
Ackattack
Ackattack's Avatar
OK, thanks for the info on the 69...I was pretty sure on that.
After posting this, and memories coming back, my rearend definatly doesn't have 1310. It uses a u-joint that is / or very close to a 1330, which would be the same width as a 1350, but with small caps. I'll need to take some measurements.
Old 04-28-2011, 08:38 AM   #5
Ackattack
Ackattack's Avatar
The 73 up is a 1310
that is some good info.....I'll have to really look through it later! (and save it)
Old 04-28-2011, 01:29 PM   #6
brad_man_72
the boat guy
their isn't an accurate ujoint application guide anywhere! 1330 is same width as 1350 but with the cups of a 1310.
Old 04-28-2011, 02:15 PM   #7
Jessechop
Thats a 1330 that you described.
1310 uses a 1.063 bearing
1330 uses a 1.063
1350 uses a 1.188
width from outside to outside
1310 3.219
1330 3.622
1350 3.622
unless I am missing somthing?
Old 04-28-2011, 02:48 PM   #8
brad_man_72
the boat guy
you got it!
Old 04-28-2011, 03:40 PM   #9
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
5150
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 04-28-2011, 07:36 PM   #10
Ackattack
Ackattack's Avatar
Good news is I figured out why my rear u-joint wasn't seating. The grease zirk buldge in the middle of the body protruded out enough that it was hitting the pinion (just barely). So I took out the u-joint and flipped it around so the grease zirk bulge is towards the driveshaft rather than the rearend. So the rearend I have does have a 1330 pinion yoke (whatever its from)
Next, I'll be ordering a longer driveshaft yoke to compensate for the different rearend. Hopefully that will resolve the vibration issues.
Thanks for the help guys.
