Better late than never
![]() Join Date: Dec 2001
Vibration
I have a vibration between 45-60 mph. It kind of feels like the engine sputtering, but if I depress the clutch it is still there. I just rotated & balanced the tires thinking that must be the problem, but it didn't help. What else should I look at? The only thing else I can think of is the driveshaft. Any other possibilities would be appreciated.
1970 C/10 SWB Stepside |
ujoints on the drive shaft will vibrate a loose or broken tranny or engine mount will also vibrate cracked brake drums bad wheel bearings as well as loose harmonic balancer and flywheels also can cause vibrations
Sounds like it might be one or more of the U-joints, since they are most noticeable at certain speeds. Also check the center support (carrier) bearing. The "engine sputtering" description has me somewhat puzzled, though. Good luck!
If with the clutch depressed you still get the vibration, focus on running drivetrain ---balanced tires? Did they check the wheels for bent? Did they check the tires for out of round?
Balancing will not pick up on a bent wheel or bad tire unless they look for it. Additional thoughts----drive shaft bent, universal joints, center support bearing, transmission mounts, shocks, front suspension. Good luck ![]() |
Robert Olson Transport
![]() Join Date: Oct 2002
what they said but start with the center support bearing that makes for wierd problems like that
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: Vibration
did you get it fixed? ifso, what was it?
