Old 07-21-2003, 06:10 PM   #1
hwiggles
Lightbulb Valve cover Leak
What is the secret to stopping Valve Cover Leaks? Maybe I'm using wrong type of gaskets(cork)? Please help my cement driveway.
hwiggles is offline   Reply With Quote
Old 07-21-2003, 06:26 PM   #2
68 Suburban
68 Suburban's Avatar
I got a nice set of valve cover gaskets at Auto Aone. I think they were felpro. They cost $19. They are hard plastic with a soft rubber that looks like a bunch of little squeegesaffect that seal to the heads and valve covers. They are reusable and I have not had a leak since.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 07-21-2003, 06:31 PM   #3
racedvl
racedvl's Avatar
A aluminum set of valve covers would also help your cause.
racedvl is offline   Reply With Quote
Old 07-21-2003, 06:39 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Look in the Chrome Dress-up Goodies section of the store for valve cover clamps, or tie-downs, or straps - shoot, I forget what they're called. What they are is a set of four chromed steel straps about 4" long with a hole in the center for the valve cover bolt. It spreads the load over more of the valve cover lip, and helps slow the rate of leakage!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-21-2003, 07:49 PM   #5
jjk3
It's just a check engine lamp.
jjk3's Avatar
I always had leaks on my 327 with the aftermarket valve covers and the cork gasket. I think it was mainly the valve covers. I ended up buying a set of Moroso valve cover gaskets from Summit they are neoprene with steel inserts, they are reusable and you don't have to use any RTV. They stopped the leaks. I still have an unopened set in my shed. I think they were $32 for a set. Kinda expensive, but well worth it.
Active Inliner---bigchevy66
68 SWB Stepside 250 L6/3 on the floor/ Hedman headers, HEI, MSD 6A box, K&N filter, Offy intake and Edelbrock 600cfm 4 barrel
Soon to have: WC T-5 five speed
66 SWB Stepside-undergoing restoration
jjk3 is offline   Reply With Quote
Old 07-21-2003, 08:10 PM   #6
jef5150
Inline 69
jef5150's Avatar
Lightbulb maybe theyre TWEEKED,,???????
sometimes on older stock valve covers,you get a "DIMPLE" on the bottom of the valve cover from the bolts being to tight,,,,you can flatten them out with a piece of wood,,,also the lip around the edge of the valve cover that is closest to the heads gets bent out,It should be straight...you can try to straighten them if theyre TWEEKED,,just a thought,,,,,, i did it too my oil pan jeff,,,,
jef5150 is offline   Reply With Quote
Old 07-21-2003, 08:16 PM   #7
jef5150
Inline 69
jef5150's Avatar
tweeked
1
Old 07-24-2003, 06:46 AM   #8
ZOOMY
leaks
Go to neoprene gaskets. Reuseable for years.
ZOOMY is offline   Reply With Quote
Old 07-24-2003, 09:04 AM   #9
Southpa
Southpa's Avatar
Examine the top lip of the head for any nicks or dents that might allow oil through. If you find any maybe some sort of hard filler like JB Weld would fix it. But apply it cleanly, you don't want pieces in your engine. If you torque a valve cover bolt down too tightly you will pinch the edge of the valve cover. This could cause a middle section to bow upwards. Also whenever you replace your gaskets make sure both surfaces are clean, clean CLEAN!
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 07-24-2003, 09:10 AM   #10
lukecp
Formerly yellow72custom
lukecp's Avatar
I have found that using the spreader bars mentioned above work good for a leak free seal. I have always used the thickest Fel Pro cork gaskets the parts store has, and "glued" them to the valvecover with Permatex Red Hi-Temp sealent, then put them on the head. So far, i haven't had any leaks. Those rubber or neoprene gaskets might be a good idea....i haven't tried any yet but i will when mine need to be replaced next.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-24-2003, 09:13 AM   #11
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
If you have the Votec center bolt style then you definetly need some nice cast aluminum valve covers like were on the Corvettes that had them. Other wise you just need to get some nice valve covers with some of those neoprene gaskets. They seem to work all the time.
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 07-25-2003, 04:50 AM   #12
jimfulco
I use a good quality cork gasket. Glue to a straight flange with yellow 3M, coat head side with Permatex #3 (Super 300), let it soak in, coat again & install with Corvair valve cover springs (load spreaders, but not chrome). Re-tighten after a year or two. They will leak again about 20 years later. Never had much luck with the neoprene ones. With the Permatex, they come right off, even after years.
jimfulco is offline   Reply With Quote
Old 07-25-2003, 12:51 PM   #13
COBALT
COBALT's Avatar
1. Good valve covers (aluminum, flat steel, etc.)
2. Hold-downs (the wider the better).
3. Some type of reusable gasket (moroso and fel-pro make the best).
4. Clean both the lip on the covers and the flange on the heads with brake cleaner and scotch brite until squeaky clean.
5. Tighten until cover completely seats, then STOP. don't overtighten.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
