Closed Thread
Old 04-09-2011, 02:00 AM   #251
fist5366
Re: Show us your projects
next step is to finish the body work
fist5366 is offline
Old 04-19-2011, 06:02 PM   #252
sonofajunkman
sonofajunkman's Avatar
This is my latest acquesition. dont know if I am going to do anything with it or just re-sell it.
sonofajunkman is offline
Old 04-19-2011, 09:42 PM   #253
99 to Life
99 to Life's Avatar
hey sonofajunkman funny you posted that, I seen that on CL
I work on my truck in titusville but live in pittsburgh
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline
Old 04-22-2011, 03:33 PM   #254
oldchevytrucks
Here's my 52 Chevy.
oldchevytrucks
52 Chevy 3100
Pics:
http://s1107.photobucket.com/albums/...2ChevyProject/
oldchevytrucks is offline
Old 04-26-2011, 11:57 PM   #255
77chris03
77chris03's Avatar
Originally Posted by pugs View Post
heres a coupl eof pics of my 57,havent worked on it in months Thought i had it sold a few times, so i bolted it together for now so i have some room and do some seriuos cleanup
you quote some women just dont get it....mine does...i have a 68 c10 she has a 50 5 window 3100....she gets it....i got someone who gets dirty in the garage with me....now thats a good catch....
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline
Old 04-27-2011, 09:32 AM   #256
waybad
waybad's Avatar
you sir are a lucky man!!
post up more picts when you can!!
waybad is offline
Old 04-27-2011, 11:41 PM   #257
55Cameo
55Cameo's Avatar
Looking nice. Where do you normally go for hang outs?
55Cameo is offline
Old 04-29-2011, 04:23 PM   #258
01spirit750
I have made some progress since these pictures were taken.
I have the front end assembled. The hood is still at the paint shop.
01spirit750 is offline
Old 04-30-2011, 11:59 AM   #259
Gman7
Gman7's Avatar
Originally Posted by yoder View Post
Heres my '49 I've been working on last few months. Air ride front and rear, parallel 4 link, 5.3l 4l60, 8.8 ford explorer 3.73 posi rear axle, 8" step notch, Ididit steering, 18x8 4.5" backspacing front, 18x9.5 5" backspacing rear. Was a longbed 3/4t.(cut box for mockup only). Hope to get the frame ready for powdercoat within the month.
At normal ride height now but will lay the running boards.
Did you have to cut out the inner fender supports to fit the tires?
Carlos G
Ride the Dream
Santa Fe, NM
________________________
Gman7 is offline
Old 05-20-2011, 11:10 PM   #260
yoder
I replaced the rear fenders with aftermarket ones that the brace fits tighter to the fender.
yoder is offline
Old 05-21-2011, 06:38 PM   #261
S10Fan
Old Heap Driver
Here's an update on mine................
The motor and trans are in place (307 TH350).
Air ride components are installed, need to finish running the lines.
Cab and bed are mounted/bolted in place.
Bed sub-floor is complete.
The bed floor will be covered with some weathered wood and as you can see, a 55 gallon drum covers the bridge notch. The barrel was stripped and sprayed with peroxide (old windex bottle), the rust formed in minutes.
The core support bracket is complete, the front clip is removed while I work with the motor and trans.
The shifter mechanism is home built and works perfectly, it's a $15 alternative to a $250 piece. The "Spoon" will be my gas pedal.
Wheels are Circle Racing 15X7 with 1" BS in the rear and 2" BS will be on the front. Using the offset wheels allowed me to keep the S-10 rear and have the same track width front and rear without a goofy looking wheel/fender combination. I still need to re-drill my hubs and axles for 5/8 wheel studs. I'll be running 57 Cadillac hubcaps with 3" bullets and wide whitewalls.
I plan to begin the suicide door hinge install in the next couple weeks.
I'm going to try and get this thing ready for a trip the Fredricksburg Virginia October '11 for the Hot Rod Rumble.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline
Old 05-25-2011, 10:26 PM   #262
wilberweb
wilberweb's Avatar
Here is my 55 Chevy 3100 second series big cab
the plan is a camaro front clip. same color as cal 58 gmc
prowler Orange. 350 Engine,auto transmission tilt wheel.
-Larry
Eugene Oregon
wilberweb is offline
Old 05-26-2011, 11:18 AM   #263
cpmskinny
cpmskinny's Avatar
Just wanted to drop a quick hello to everyone on this wonderful forum. I purchased 2 rough trucks, a 49 and 53. Hopefully I will be able to make a nice running Rat Rod out of one of them. Thanks for all of the great information, looking to start my frame swap in the next couple of months or so. I sure have got my work cut out for me! Here is a pic of the 53.
cpmskinny is offline
Old 05-26-2011, 11:40 AM   #264
FFredo
WOW, very inspersational thread folks!!
Here's mine. 59 Apache Fleetside. I took the bed off last weekend to see where I stand. Looks like I'm standing in a hole! I can't park the truck since I need to drive it daily so it will take longer then I hoped. I have a box coming in (today) from LMC and it holds a few patch panels, new cab mounting hardwear, electrical schematics to fix the butcher job from the PO and all rubber for front sheet metal.
I will have a 4 day weekend coming up. Plan to pull the motor and do a Krylon rebuild and also replace the front fenders. If time allows I will lower by removing a cpl of leafs from all 4 corners.
Over the summer I will get the bed back together.
FFredo is offline
Old 05-28-2011, 10:58 PM   #265
JPH
JPH's Avatar
cpmskinny..../That looks a lot like my truck
1954 Chevy 3100 SB 400 700r4
Sold (Stupid of me)
http://s1080.photobucket.com/albums/j328/54chevy3100/
JPH is offline
Old 06-16-2011, 04:18 PM   #266
Dan in Pasadena
Dan in Pasadena's Avatar
Hi Fredo,
So that you, huh? You're an old dude, huh...just like me!
Seriously, I thought maybe you were a kid. I think I'm older than you at 56 and I'm just getting back to the '55-'59's after losing my old '57 in my divroce of 11 years ago (can it be THAT long?)
My Dad had a '59 Fleet just like yours when I was a kid. First of his trucks in which my feet would touch the floor. Bfore that a couple '48-'53 five windows. I helped him take it the Fleetside from a straight six to a 283 - which ran GREAT - and then later to a 348 (I handed him wrenches while he cursed it out!). I actually found the SAME truck still with the 348 for sale in Hemet about 6 months ago. I was tempted to buy it but I couldn't swing it at the time...damn.
Maybe we'll run into each other at Pomona or somewhere in the future. Take care, Dan
Dan in Pasadena is offline
Old 07-24-2011, 09:12 AM   #267
bamabob
bamabob's Avatar
Kind of new here. Been lurking awhile soaking up some knowledge but haven't posted. Thought I'd join in and show what I'm up to. Bought a trailer load of 49 parts a few months back. From there went to work on a 2" top chop, replaces rusty panels, removed all the vent openings and just yesterday finished the floor fabrication adding a transmission tunnel.
This is a great forum with tons of info thanks to the folks that take the time to help others out. Glad I found it.
bamabob is offline
Old 07-24-2011, 10:43 AM   #268
IndyBowtie
IndyBowtie's Avatar
Picked up a 283 corvette engine for the truck. Now gathering parts needed for the swap.
IndyBowtie is offline
Old 07-24-2011, 12:19 PM   #269
S10Fan
Old Heap Driver
Welcome!
Looks like you've got it going your way!
Bryan
S10Fan is offline
Old 07-24-2011, 08:39 PM   #270
bamabob
bamabob's Avatar
Thanks for the welcome Bryan!
bamabob is offline
Old 08-09-2011, 12:12 PM   #271
SSABMUD
SSABMUD's Avatar
Working on it as time permits, which seems to be hard to come by lately.
Wade
SSABMUD is offline
Old 08-09-2011, 12:16 PM   #272
Kabwe
Certified Car Nut
Kabwe's Avatar
SSABMUD,
That is a really nice project you have going there. I likes, I really likes.
Kabwe is offline
Old 08-09-2011, 12:27 PM   #273
SSABMUD
SSABMUD's Avatar
Thanks Kabwe,
That was funny, as I was just looking at your pictures of your truck. You are doing some fine work there my man. Love the tilt hood.
Wade
SSABMUD is offline
Old 08-11-2011, 11:44 PM   #274
Kodiaks53
Here's my 53, its now fully disassembled and awaiting the rebuild. I have a s-10 frame, 350 4bolt main, 700r and a lots of work to do!
Kodiaks53 is offline
Old 08-12-2011, 10:05 AM   #275
SSABMUD
SSABMUD's Avatar
Let the fun begin. Looks like you have a pretty solid truck to start with.
Wade
SSABMUD is offline
Closed Thread
