Old 04-26-2011, 09:53 PM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Think my horn is toast. What horn(s) were used on these trucks?
I think my horn is shot on my '69 C20. It sounded horrible then stopped working. I removed the horn and bench tested it with my battery charger and it beeped once and that was it. Does nothing. I don't have my steering wheel installed, but when I complete the circuit by touching the horn wire to the column I can hear the relay clicking. So I plugged a 12V test light into the horn wire in the engine compartment and it gets power when I touch the horn wire to the column. Does this make sense that it would be the horn?
What horn or horns were installed on these trucks? Were they a single horn or double horn set up? I only had one horn and one wire. The horn appeared to be an aftermarket horn. Where can I get a replacement horn set up if this is indeed the problem?
Not sure if this is the right location for posting this thread.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 04-26-2011, 10:27 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Think my horn is toast. What horn(s) were used on these trucks?
personally, I'd go to a junk yard. For 5 or 10 bucks you can get 2 horns, a high and a low, off the same car and have a great sounding horn on your truck. A single tone always sounded chintzy to me, but a bi tone, or even tri tone sounds classy.
Or, you could run to napa and get a horn or two and splice the wire to make there universal (read, fits nothing) set up in place... but those don't last long... couple years and they crap out (I blame china) and you get to do it all again.
Old 04-26-2011, 10:36 PM   #3
derotoreut
derotoreut's Avatar
Was the two-horn system standard? What would I look for in a junk yard to get this out of? Seems like it would be better. How is it wired? I have aftermarket wiring harness with only one wire. Would I need another wire or just tap another wire off the one?
~ Dan
Old 04-27-2011, 01:38 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My truck came with two horns, but you say yours has just one wire. No worries, easy enough to extend a wire to a second horn. I agree with Andy, go to a boneyard. I'd look for any late-model full-size GM truck or car -- they should have good powerful hi/low horns.
The green wire sends 12vdc from the horn relay (under the dash) to the horns, which are mechanically grounded to the core support. So it's important to make sure the core support is properly grounded.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 04-27-2011, 03:41 AM   #5
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
The wire Harness only has one green wire that goes to the green horn wire there is another green wire its like a jumper wire then you plug that end to the other horn. something like that sorry if I make it sound confusing. I would take a picture for you but im at work. Let me know if you would like a picture and I can take one later tomorry and post it for you. You might be missing the Jumper wire it is also green.
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 04-27-2011, 04:39 AM   #6
heeroyue2002
fat old dude
heeroyue2002's Avatar
i have an old ahooga(sp?) horn and the stock horns.
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 04-27-2011, 10:27 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Here's a pic from a recent thread, showing one horn & the wiring going from it to the other horn.
- Mike -
RIP El Jay
Old 04-27-2011, 08:23 PM   #8
derotoreut
derotoreut's Avatar
The single horn that came on the truck was a cheap aftermarket one. You're right Longhorn Man... China. I think I'll take you up on the boneyard idea and look for a high/low horn set up. How would I wire that though? Stocker's pict shows the green wire going into the first horn and then out to the second horn. Doesn't the horn have to have a ground wire to chassis? Is it ok to run the green wire in/out of the first horn and then run only one ground wire on the second horn to the chassis? Or do you tap off of the green wire and run one to each horn and then run chassis grounds on each?
~ Dan
Old 04-27-2011, 09:28 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Tap off of the green wire and run one to each horn. That's it. The pic shows a piggyback connector, not in & out.
The horns are grounded by their mounting bolts (which is why the core support must have a good ground).
- Mike -
RIP El Jay
Old 04-27-2011, 10:09 PM   #10
derotoreut
derotoreut's Avatar
Oh OK. My single horn was wired with green wire in to a terminal; and the second terminal was wired as ground to core support. Are you saying there isn't a ground wire off the second terminals on the two-horn set up? Only grounded through horn mounting bolts?
~ Dan
Old 04-27-2011, 11:18 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yes, that is correct.
- Mike -
RIP El Jay
Old 04-27-2011, 11:51 PM   #12
derotoreut
derotoreut's Avatar
Got it! Thanks Stocker.
~ Dan
Old 04-28-2011, 09:43 AM   #13
cdowns
cdowns's Avatar
try spraying wd40 into the horn to clean up 40 years of dust and crap off the vibrating diaphram to allow for better louder clearer operation // as stated clean the mounting surface real good to allow for good ground and do not overlook making sure you've got a good ground connection between the core support and the frame rail
Old 04-28-2011, 09:49 PM   #14
derotoreut
derotoreut's Avatar
I could do this on the one I have except its a cheap aftermarket piece of junk. When I pick up a hi/low one from the boneyard I'll keep this in mind.
~ Dan
Old 04-29-2011, 05:52 PM   #15
derotoreut
derotoreut's Avatar
Would you believe I checked a couple of junk yards and no one has older GM hi/low horns. The ones they do have don't work. Thought for sure I would be able to find some. So if anyone has any insight on where I could get a working two horn set up for my '69 C20 let me know.
~ Dan
Old 04-29-2011, 06:30 PM   #16
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
On the original GM horns, the ground is through the mounting bolt. On your aftermarket horn, the ground is through the second wire to the core support.
With dual horns, they usually used a piggy back connector so that two wires could be connected to the same terminal. that way you'd be able to power the other horn.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 04-29-2011, 09:00 PM   #17
Legolas894
Chemist under the hood...
Legolas894's Avatar
My '98 suburban has a hi and lo horn. The lo tone went and I got one from the 88-98 truck parts forum. You can pick those horns up almost anywhere but they do have a two-prong connector on them.
It's funny about your '69. On my '67, I had the same thing- a single horn that suddenly sounded like a sick goose. Then it stopped altogether. I took the horn off and sanded off the spot where it attached to the rad support and it was a lot better but I still didn't think a one-note horn matched the truck so I picked up some horns from a garage sale and put them on. The two-note is loud and clear and sounds like a truck now.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
