Old 04-07-2011, 09:14 PM   #1
Gyawo
Tires
I am looking at putting a 3 inch lift on my '86 K5, and was wondering what sort of tires some of you guys are running with the same lift. I was thinking about some 35" BFG's, but the 3" lift kit says it can fit up to 33" tires.
Thanks for any/all input.
Grant
Gyawo is offline   Reply With Quote
Old 04-07-2011, 09:44 PM   #2
Psycho71
Psycho71's Avatar
Re: Tires
Yep, 35's might fit on a 3" lift, but will likely rub w/o any fender trimming. Most 4" lifts say they'll work with 35" tires.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 04-07-2011, 09:48 PM   #3
Gyawo
Re: Tires
Thanks for the reply, I may have to consider a 4" then, or just modify the fenders till it does not rub. It has a 305 in it now, plans are to eventually put a 383 into it so there will still be room in the engine bay.
Old 04-07-2011, 09:49 PM   #4
ryanmcb
Re: Tires
I agree with psycho. You can run 35's but expect some rub while turning. 33's are perfect for that lift. Another inch would solve your problems if you want 35's to clear.
ryanmcb is offline   Reply With Quote
Old 04-07-2011, 09:55 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Tires
Yea I would do 33's with that and 4" lift would fit 35"s way better!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-07-2011, 10:00 PM   #6
Gyawo
Re: Tires
I might be growing 4" inches this summer then Any suggestions on lift kits? I have been looking at BDS and tuff country. I kind of don't like how much the tuff country is for the lift kit, plus the longer shocks, the BDS is a little cheaper, still need to buy the shocks with that one.
Grant
Old 04-07-2011, 10:11 PM   #7
Hoods69BadBowTie
Chevys Kick A$$
Re: Tires
Sweet if you can I would better to have more lift then not enough! Tuff countrys not to bad I have ran Skyjacker as well and really liked them I had there 4" and 6" lift kits both with blocks in the rear. Very happy with both
-LATER
Old 04-28-2011, 03:44 AM   #8
Hotrodd 72
Re: Tires
heres my 83 with a 91 grill...4" lift and 35's i had to trim the front fenders very little you cant even tell unless i pointed out
Hotrodd 72 is offline   Reply With Quote
Old 04-30-2011, 12:52 AM   #9
Hoods69BadBowTie
Chevys Kick A$$
Re: Tires
Damn sweet looking Burb. Looks great with the lift and tires
-LATER
