07-20-2003, 04:09 PM | #1 |
85 k10 f.s.
I have not been on the board for couple of years, but hello to everyone. I am selling my 85 k10 lwb. Within the last 2 months I have installed a new 6" Superlift lift lit, 3" Body lift, late model 14 bolt rear and a Dana 44 front, The rear has 4:56 gears already and I have the 4:56 gears ( not installed ) for the front. Also there are 4 new 16- 38.5 x 16.5 TSL Super Swampers ( less than 200 miles ), 4 new Eagle Alloy 589 series 16.5 x 12 wheels. The truck had 2 aftermarket doors installed when I bought it. I am not crazy about them, they dont fit that great, but they do have new power window motors and new door panels. I bought 2 perfect doors ( roll up window style ) to replace them with but I have not had time yet. I added 2 new Carr steps and I have 2 stainless mirrors that I also have not had time to install yet. I am asking $3500 dollars for the set up the way it is or I will remove the late model 14 bolt and install the other 14 bolt rear I have, that came with the Dana 44 when I bought another truck for the running gear. The truck will be $ 3000.00 then. I paid $500.00 for the late model 14 bolt and gears and will need to get my money back out of it. Now having said all of that, here is the the condition of the rest of the truck. 305/700r4 with a 208 transfer case, body is straight. Needs passenger rocker panel, which I have, also needs cab corner patch on drivers side which also have. Motor runs fine but has a jillion miles on it and will need to be replaced eventually. Tilt column is loose and worn out but once again I already have the replacment for it. Dash is cracked as usual, and seat needs to be redone. Truck is located in central Florida. the stereo does NOT go with the truck, nothing special but I have another truck to put it in. If I new how to post a picture I would, but I tried for an hour no luck. E-mail me if you have any questions. Thanks Don
07-20-2003, 11:08 PM | #2 |
If you want to email me the picture, I will try to post it for you. Probably needs resized. Email it to commagic@bright.net.
Keith 70 Chevelle Malibu SS Clone 468/Auto 72 C10 SWB 350/Auto 13 Camaro SS/RS 6.2/Auto |
07-21-2003, 09:47 PM | #3 |
Here are the pics!
07-21-2003, 09:47 PM | #4 |
2
