Floor shifter
I did a quick search but didn't see what I needed. This is probably easy for the pros.
How do you know where to cut the hole to put in a B&M Mega shifter in the floor? Thanks alot
1986 2wd 305 longbed WTF have I done ![]() |
Re: Floor shifter
all you need is a hole for the shift cable!...we are talkin automatic aren't we?
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Re: Floor shifter
I have installed (2) of these over the years. One of the advantages of a cable operated shifter is you place it wherever you want, as long as it is in reach of the cable.
Re: Floor shifter
Yeah sorry it's a TH350. That's sweet it's that easy.
Thanks Duke
Re: Floor shifter
You have to:
-Drill holes for the shifter -Cut hole for shifter cable -Cut holes in the carpet or mat -Get under the truck and install the cable brackets and the lever arm for the cable. You will also need to adjust the cable -Extend the neutral safety switch and reverse light wires to the shifter -Trim the plastic shroud to match the contour of the floor -Make some sort of bracket to hold stock shifter on the column in the park position Not a tough job. Lots of fun to manually shift! ![]()
1977 GMC Sierra Grande Last edited by Pyrotechnic; 04-29-2011 at 11:17 PM. |
Re: Floor shifter
and make sure the shifter cable is going through the floor as straight as possible.. mine had to much of a bend it it, resulting in me breaking the cable over time.
Thanks, John 85' c10 swb 383 th400 ran: 13.26 @ 99 w/ a 1.8 60' ![]() |
Re: Floor shifter
Once its in make sure the shifter works in every gear before starting the truck.
