Old 07-22-2003, 01:29 AM   #1
Mustard Mobile
Former Evolutionist
SM 465 stick shift removal
Hello all,
Since I cant do the search option I will make a posting. I have done the stick shift removal before but it has been too many years. As I remember you press down the center cap and turn to unlock. Then you place the stick shift halfway between neutral and reverse and pull up? Is this correct?
Thank you.
andy
Current project- 71 3/4 Ton 4x4
Future Project- 1948 fleetline electric conversion
Mustard Mobile is offline   Reply With Quote
Old 07-22-2003, 02:37 AM   #2
hjalbert
cracker
hjalbert's Avatar
its only been months since i did mine and i have allready forgot, but i thought first you had to remove a nut or an allen screw on the side of the housing first? i think
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Harry John Albert III
located in Phoenix, AZ
1972 GMC JIMMY,
1969 lwb Chevy Frame,
1999 bmw k1200 ltc
1992 Kawasaki concours
1991 bmw k75
1973 cortez motorhome
hjalbert is offline   Reply With Quote
Old 07-22-2003, 05:18 AM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
If you're just pulling the shift stick.. you only have to press down and turn the cap about 45 degrees clockwise -- I think -- using tool J-@#$% [I made one by cutting a 5/8" slot in a short piece of 2x4 wood] ..then the stick should lift right up. There is a half-ball and spring underneath that come out too.
If you're pulling the turret plate (top) off the tranny ... then you need to be almost in Reverse to get it off. The top plate has to come off only if you are pulling the engine and trans as a one-piece unit.
Old 07-23-2003, 01:12 AM   #4
Mustard Mobile
Former Evolutionist
Thanks for the replys. I know the last time I did not use any special tools. I will give it a try unless anyone else has any other recomendations.
