07-20-2003, 08:39 PM | #1 |
fuel line help quick plz
what size should the hose be to a eldebrock 1406 i used 5/16 was 3/8 now black smoke bad
07-20-2003, 08:44 PM | #2 |
2 tons of fun
I use 3/8" line on mine. Lumpy
67 Chevy,Short/Fleet,350,Saginaw 4-Speed,Lowered 4x2,small window,P/S,Edelbrock Intake/Carb,HEI,Gear Drive,Crane Cam 274H Three Rivers, Ca Pics at: http://www.cardomain.com/id/lumpy454 |
07-20-2003, 09:37 PM | #3 |
its all about the +6 inches
Should have a 3/8 line, but it sounds to me like your carb needs adjusted. Start with adjusting the 2 screws in all te way and backed out by 1/4 turn.
07-20-2003, 09:39 PM | #4 |
Watch out for your cornhole !
fuel line size won't cause it to black smoke. You have carb problems.
Too small of a fuel line will hurt power at WOT Too large of a fuel ine won't hurt anything. |
07-20-2003, 09:48 PM | #5 |
just an fyi I use 3/8 line too. sounds like carb needs adj.
does it back fire ot sputter at any time or act sluggish?
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ "Why couldn't you have just put the bunny back in the box?" ~ |
07-20-2003, 09:54 PM | #6 |
yes
07-20-2003, 10:13 PM | #7 |
Glowing since 1978
What fuel pressure is the supply to the carb at? These edelbrocks are picky about to hi a supply pressure. It will run rich all day long if supply pressure is to hi.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
07-20-2003, 10:42 PM | #8 |
i really dont know just a stock fuel pump
07-20-2003, 11:35 PM | #9 |
stock pump should be fine , i am running same carb and stock pump., Check your timing and points, adj carb settings
07-22-2003, 02:50 AM | #10 |
Sure you didn't get a little speck of something under the float valve?
