Old 05-02-2011, 12:15 AM   #1
JORGIE95961
auto shiofter help super tough to shift
first time shifting this column in the last 20 years. it was in the cab im using . and since im doing a manual to auto swap im using it. but the damn thing is super hard to shift . Im sure its probably just a lube issue. IVE DISCONECTED IT FROM STEERING COLUMN AND SHIFTED WITH MY HAND SO IT IS DEFINITELY NOT THE LINKAGE . but i have no idea what to take apart to lube any simple fixes to thios before i give up and buy a different column? i shift the trany manual and thats a piece of cake . but the shifter man thats stiff.. any help for a mediocre parts swapper is gladly welcomed and apprecieated!!!!
Last edited by JORGIE95961; 05-02-2011 at 09:05 AM. Reason: forgot to mention linkage sorry
JORGIE95961 is offline   Reply With Quote
Old 05-02-2011, 04:13 AM   #2
60ratrod
yes, i do
60ratrod's Avatar
Re: auto shiofter help super tough to shift
check for any binding in the linkage.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 05-02-2011, 09:11 AM   #3
ubtripn
ubtripn's Avatar
I had the same problem and I shot PB Lubricator down and around where the shifter enters the column and BAM, smooth as silk, it really tripped me out how well it worked. Should work for you too if there are no mechanical binding issues.
ubtripn is offline   Reply With Quote
Old 05-02-2011, 09:21 AM   #4
68gmsee
Active Member
68gmsee's Avatar
More than likely it needs relubing as mentioned above. If you're not sure, you can simply disconnect the link at the column.
If you're sure it's in the column then do as suggested above and slowly work the shift lever up and down. Do not use extreme force or you will break the shift lever pivot end.
On my old 69 I actually removed the column and dismantled everything and regreased the shift column and steering mechanism.
68gmsee is offline   Reply With Quote
Old 05-02-2011, 09:27 AM   #5
JORGIE95961
Re: auto shifter help super tough to shift
ttt
Old 05-02-2011, 09:31 AM   #6
cdowns
cdowns's Avatar
i like to spray heavily with WD40 to clean out old dirt dust and petrified grease then when it has loosened up i'll spray with white lithium grease for a longer lasting lubrication effect
Old 05-02-2011, 09:32 AM   #7
JORGIE95961
thanks guys . took the lever out and shot some lube in it last night. this morning still pretty hard.. I took out the little bolts on the steering column that hold the lil shift bump thingy in the engine compartment. and it shifted smother beacause that lil part moves now when i shift. but im sure thats not supposed to move..
Old 05-02-2011, 11:26 AM   #8
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
mine is hard to get in and out of park, is that the same problem your having?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 05-02-2011, 11:38 AM   #9
JORGIE95961
all the gears bro. its definitely in the column. im gonna try and tear it apart tonight.. If for you its just outa park its probably hittingthat little bump below the shift lever think in the engine compartment try a lil bit of grease on the bump..
Old 05-02-2011, 11:52 AM   #10
vasquezmrysvll
"the other guy"
will do, good-luck with your trouble shooting.
Old 05-02-2011, 03:53 PM   #11
Keller
Keller's Avatar
i had the same problem, took the steering wheel and horn/turn signal stuff off and there's a cylinder that slides up and down the steering column and they were binding together. put a small amount of brake parts grease on it and she's good as new.
1972 C10 Longbed 350/350
Keller is offline   Reply With Quote
Old 05-02-2011, 04:03 PM   #12
68gmsee
Active Member
68gmsee's Avatar
fyi:
http://67-72chevytrucks.com/vboard/s...d.php?t=425781
Old 05-02-2011, 04:03 PM   #13
JORGIE95961
Originally Posted by keller View Post
i had the same problem, took the steering wheel and horn/turn signal stuff off and there's a cylinder that slides up and down the steering column and they were binding together. Put a small amount of brake parts grease on it and she's good as new.
is it pretty obvious once i take it apart?
Old 05-02-2011, 04:04 PM   #14
JORGIE95961
Originally Posted by 68gmsee View Post
thanks.. But i have an auto shifter
Old 05-02-2011, 04:42 PM   #15
Keller
Keller's Avatar
yes, once you get the wheel and horn/turn signal out of the way you will be able to move the shift lever and see exactly what I'm talking about. just pay careful attention to how everything comes out.
Old 05-02-2011, 04:56 PM   #16
JORGIE95961
thanks keller i owe ya one
