Old 05-01-2011, 11:16 PM   #701
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
Forgot to post pic. Seeing the pic i now know i need to get real batt hold down. The hitech bundge cord has seen better days.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 05-02-2011, 06:50 PM   #702
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
maybe put the battery....or even the ecm.... in a metal/plastic box?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-02-2011, 08:02 PM   #703
bayou boy
bayou boy's Avatar
[QUOTE=85burb;4656590]Sure dont live there any more thank goodness. Our trailer was in need of a big dumpster. The park was ok but our unit was smooth wore out. The owners were ok as well. What trailer did you live in.[/QUOTE yeah i agree mine was new though 2nd on the right my pickup was always covered
all i know is that its going to be orange
bayou boy is offline   Reply With Quote
Old 05-02-2011, 08:04 PM   #704
85burb
85burb's Avatar
[quote=bayou boy;4658658]
Originally Posted by 85burb View Post
Sure dont live there any more thank goodness. Our trailer was in need of a big dumpster. The park was ok but our unit was smooth wore out. The owners were ok as well. What trailer did you live in.[/QUOTE yeah i agree mine was new though 2nd on the left
Did we live there the same time? I think i remember a orange truck that was usually under a car cover. You lived next to the lady with 90 kids then.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-02-2011, 08:07 PM   #705
bayou boy
bayou boy's Avatar
yeah thats the one im glad ive upgraded quiet bliss on the lake now
Old 05-02-2011, 08:07 PM   #706
85burb
85burb's Avatar
I dont know about a box but i may put a cover over it so the rain does not drip on to it. What box do you have in mind?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-03-2011, 10:01 PM   #707
68GMCCustom
if you didn't get the plastic cover that goes over the ecm...you should be able to get one cheap.
Kurt -
Old 05-03-2011, 11:13 PM   #708
85burb
85burb's Avatar
I did not know one was avalible. It says it is water proof when it is pluged in to the harness. I have looked on line but i did not find anything that would look good.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-03-2011, 11:15 PM   #709
85burb
85burb's Avatar
That is a massive upgrade! I thought i made a big upgrade moving to the appt i have now. Dang it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-04-2011, 11:26 AM   #710
68GMCCustom
so when's it going in?
Kurt -
Old 05-04-2011, 11:35 PM   #711
85burb
85burb's Avatar
Would have liked to do it this weekend but i work an sat. And moms day sunday. The only thing that is going to take some time is the return line. I plan to use the factory return that my pump had but am not sure if or how to get the new hose to seal good on old hose. The return is 5/16 i think. The efi is 3/8 or -6 but 3/8 is the i.d. I am not sure if i can get the -6 to clam down on the 5/16 or not. The kit has hose clamps on the return side so it is not that much psi. That is the only thing that could hold me up so i want to have full weekend to do it just in case. Next week seems to be the week. I may install my regulator This weekend. I am taking baby steps sorry.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-07-2011, 10:26 PM   #712
85burb
85burb's Avatar
Do yall think a 5/16 return line will work. The kit has a -6 supply and that is 3/8 i.d. My origanl engine had one of them 3 hose pumps and the 3rd hose is a return hose i am told and i want to use it cause it is steel and would not have to drop tank or add anything. If it works it would be great.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-08-2011, 01:11 PM   #713
85burb
85burb's Avatar
I just ordered a 3/8 hose barb fitting for my return line. I plan to shove a 5/16 hose over it and connect to my factory return line. Then i just need a 5/16 fuel line and will be all set. I hope..... So far it is planed for next weekend.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-08-2011, 01:16 PM   #714
MTCK
MTCK's Avatar
That should work fine. As a check you can put a fuel pressure gauge inline on the return near your throttle body. It should read nearly zero. As stated before you are going to want a baffled tank, or don't go below 1/4... LMC sells them for cheap, or you can get a junkyard 87-91 burb tank. I couldn't find one for my pickup, but I only had 1 year that would work. Can't wait to see the install.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 05-10-2011, 05:48 PM   #715
y5mgisi
Second Chance Program
y5mgisi's Avatar
Just thought i would let you know that this guy on Coloradok5.com just finished an install of the fast EFI on his big block and seems pretty happy with it so far.
http://coloradok5.com/forums/showthread.php?t=281710
can hardly tell its not a carb!
y5mgisi is offline   Reply With Quote
Old 05-10-2011, 06:06 PM   #716
y5mgisi
y5mgisi's Avatar
Just for fun, here is some info i found on it,
we tuned the carb as well as we could, then took the car on a 100-mile mileage loop. The carb delivered 13.2 mpg. With EZ-EFI, the exact same mileage loop brought home 18.5 mpg.
from here,
http://www.hotrod.com/techarticles/e...ion/index.html
Old 05-10-2011, 09:40 PM   #717
85burb
85burb's Avatar
from here,
I have read that exact article several times. I can pretty much resite the hole thing. I hope to get 10-12 cause i get about 7 now. Cant wait.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-10-2011, 09:41 PM   #718
85burb
85burb's Avatar
Thanks i will have to read that article. The look is a nother reason i like this kit so much.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-10-2011, 10:07 PM   #719
85burb
85burb's Avatar
Dang accelerator cable snapped today when i was warming truck up. Got in and pushed pedal to reset fast idle and after a min i tried to tap the pedal and heard crunch noise and pedal went smooth to the floor and staded there. Good thing wife has a car or i would have to walk 12 miles home and 12 back to work. Any way got new one and will have to install it tomorrow at work.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-10-2011, 11:02 PM   #720
y5mgisi
y5mgisi's Avatar
I always think i should carry one with me. One time my cousin and i were driving in his suburban and his cable snapped about 3 blocks from home. We just popped the hood, i crawled up in there and ran the throttle while he drove! But, 3 blocks is a way lot different then 12 miles! That would not be ok.
Old 05-10-2011, 11:23 PM   #721
85burb
85burb's Avatar
If i had to i was going to use a shoe string. Would have ben iffy at best. If i would have looked at everything i would have just fixed me up a cable out of wire and limped it home. Now it is sitting at work and i have to go pick it up after work and that means i have to drive to work twice. Horible waste of gas.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-11-2011, 02:57 PM   #722
kSStamp0182
LSX addict
kSStamp0182's Avatar
i would laugh so effin hard if i passed at this moment.
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration]
kSStamp0182 is offline   Reply With Quote
Old 05-11-2011, 10:37 PM   #723
85burb
85burb's Avatar
Well i installed the biggest pos throttle cable ever made at lunch today. For some reason it would not clip into my firewall. Then it would not clip into my throttle pedal then it held the carb open so it idles at 1100. So modifyed the clip for fire wall then modifyed the the firewall pas threw so it would let carb shut all the way. So i should have used the shoe lace and saved 14 bucks.
Also got my fitting in mail to finish the efi. I will be installing it this week end. Cant wait. I hope it is all it is cut out to be.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-12-2011, 11:25 PM   #724
85burb
85burb's Avatar
Well i have just read the 33 page manual again for my efi and still dont fully understand how it works. Guess that is why they dont let you play with the fuel maps and that stuff. I cant wait to install in sat. I figure is should not take that long. All i have to do is install fuel pump in other ones location and install t/b and regulator and plumb my return line in and set the fuel psi. Then 9000 connections and turn key. Cant wait! Almost as exciting as the day installed the hole motor. Seen my next prodjects motor at the local cruse night. A ZR1 corvette motor. Man that was nice. You can actually change the spark plugs rather easy on the monster. I was surpprised. The rear tires on that thing make my 11.4 inch wide tires look like skinnys.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-13-2011, 01:11 AM   #725
y5mgisi
y5mgisi's Avatar
That would be so insanely bad ass!
