Old 05-03-2011, 02:17 PM   #1
Clyde65
Clyde65's Avatar
anyone got a 6 guage dash template?
I would like one so I can cut my dash out of wood or maybe aluminum.
Thanks guys!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-03-2011, 02:26 PM   #2
gloriavoxdei
gloriavoxdei's Avatar
Re: anyone got a 6 guage dash template?
I'm gonna do the same thing outta walnut, I could use one also
1978 GMC Jimmy, 400, th350, np203 with part time conversion, Fibrecraft popup camper, soon to get a 14 bolt/d44 swap
2001 Yukon XL2500, 6.0, 4L85E, 4x4, family truckster
gloriavoxdei is offline   Reply With Quote
Old 05-03-2011, 05:00 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
whole dash? or do you mean just the face of the instrument panel?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-03-2011, 05:24 PM   #4
Clyde65
Clyde65's Avatar
Face of instrument panel for aftermarket gauges. I just dont want to spend $150.00 on a billet one, besides that would go well in my truck.
Clyde65
Rebuild of Clyde
support our troops!
Old 05-03-2011, 05:31 PM   #5
barry h.
barry h.'s Avatar
If it is for a 65 what i did for a 66 i had was to take the glass out of your cluster and trace it on to a thin peice of wood.use the guages you want and trace and then cut with a hole saw.you might have to trim a little then stain,will look great
barry h. is offline   Reply With Quote
Old 05-03-2011, 05:36 PM   #6
slepysal
slepysal's Avatar
On my 60' I used masonite board to mock my dash insert up. I coverd it with some chrome vinyl sign decal material. It was onlly going to be temporary , just a pattern but that was 5 years ago and it has held up fine and was real easy to fab up.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 05-03-2011, 05:49 PM   #7
Clyde65
Clyde65's Avatar
I currently have a wood insert my dad made, it is for 5 gauges, decided to put a tach in, soooo..
Clyde65
Rebuild of Clyde
support our troops!
Old 05-03-2011, 06:20 PM   #8
slepysal
slepysal's Avatar
Can you use yours to make a new layout ?
Old 05-03-2011, 11:33 PM   #9
SCOTI
SCOTI's Avatar
Cardboard or masonite works well. I used the existing clear dash lense.
I taped over it w/blue painters tape & used poster-board circle templates to get an idea of where I wanted things. The circle templates were indexed vertically/horizontally to put reference marks (they help easily locate the C/L of where to drill).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-04-2011, 03:18 AM   #10
Gianyveedub
Gianyveedub's Avatar
I did what someone mentioned. I took the glass/plastic face and took it to tap plastics. Had them cut it the the shape of the glass. Then I took it home and made a template of where the gauges were going to go and busted out the hole saw.
Gianyveedub is offline   Reply With Quote
Old 05-04-2011, 10:00 AM   #11
Clyde65
Clyde65's Avatar
this is my DD, so I dont want to have it down for anytime. I am going to see if I or my dad has an old dash surround and maybe I can make it our of smoked plexiglass.
Clyde65
Rebuild of Clyde
support our troops!
Old 05-04-2011, 11:01 AM   #12
SCOTI
SCOTI's Avatar
I disassembled the cluster & used the outer bezel to trace the physical opening of the cluster onto some poster board. I included reference marks & such to make things easily repeatable.
I made everything work off the template so you could do the same to determine your layout dimensions w/o having extended downtime.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-04-2011, 11:08 AM   #13
slepysal
slepysal's Avatar
Carefull cutting the plexiglass it cracks easy. I was able to make mine in one afternoon . No real down time
Old 05-04-2011, 12:09 PM   #14
SCOTI
SCOTI's Avatar
x2. Cut smaller holes & file to fit.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-04-2011, 12:21 PM   #15
jimmydean
jimmydean's Avatar
What about the lens? I have seen replacements, but they are stock. I want the stock look with black numbers and letters. Is there a vinyl kit or something? I could take the glass out and have one made, but it would be nice to do it myself.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-04-2011, 12:21 PM   #16
impalaboy9
impalaboy9 is offline   Reply With Quote
Old 07-25-2012, 01:54 AM   #17
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Did anyone ever locate a template?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-25-2012, 01:35 PM   #18
65Gregg
65Gregg's Avatar
I have a panel that I'll be taking apart in the next few weeks if your not in a huge rush..I can trace it for you then.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 07-25-2012, 03:49 PM   #19
badriand
badriand's Avatar
Same here, found some hardy-board out beside work about to go in trash. Worked out well.
badriand is offline   Reply With Quote
Old 07-25-2012, 04:26 PM   #20
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I have a stainless piece cut to fit the bezel with a center tach hole punched; I made a couple and only used one, so this ones left over if anyone wants to have the hard part done already Just gotta punch the other gauge holes and polish her up.
Old 07-26-2012, 12:40 AM   #21
Captainfab
60-66 Nut
I could probably draw one up in autoCAD. Are those gauges you bought 2-1/16" diameter?
Old 07-26-2012, 12:51 AM   #22
LostMy65
LostMy65's Avatar
I was also thinking of drawing one up in cad.
One thought I had was to scan mine on a flatbed scanner, and then import the image into acad.
Old 07-26-2012, 12:54 AM   #23
Captainfab
60-66 Nut
Yeah, if you have a flatbed scanner big enough, that would be an easy way to get a basic outline to start with.
Old 06-03-2021, 07:28 PM   #24
LostMy65
LostMy65's Avatar
Went searching for dash gauge template thread and forgot I was involved in this one.
Gotta scan mine and trace it in CAD.
In the meantime, has anyone have different template layouts for various guage layouts?
Old 06-04-2021, 11:31 PM   #25
AcampoDave
AcampoDave's Avatar
Here's a link to a short thread I did when I made mine. It has a few good pics of my layout. https://67-72chevytrucks.com/vboard/...d.php?t=810650
AcampoDave is offline   Reply With Quote
