Old 05-03-2011, 08:16 PM   #1
jjtackleberry
jjtackleberry's Avatar
Oil line please help.......
will this work with a plastic oil line....
I'm putting in a OEM oil gauge and have copper line, but the plastic would be so much easier to feed through the fire wall....
Any help would be great....
'71 Chevy LWB all OG
'86 Chevy LWB all OG
It's all a matter of perception
jjtackleberry is offline   Reply With Quote
Old 05-03-2011, 08:21 PM   #2
Fldawg
Fldawg's Avatar
Re: Oil line please help.......
yes it will work , but i would suggest running your plastic line thru small rubber vacuum line so it does not kink plus it will protect the plastic line. hope this has helped
Fldawg is offline   Reply With Quote
Old 05-03-2011, 08:45 PM   #3
elf w/capital T
yup, most definitely use the plastic and even use the rubber hose over it, it will save its life for when well... you are under the hood n looks cleaner
elf w/capital T is offline   Reply With Quote
Old 05-03-2011, 08:55 PM   #4
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
when you say will this work and have a picture of a brass fitting, I take that to mean that you are asking if that fitting will work with the plastic line.
Yes, you can use plastic line but you may need to change the type of brass connectors. A plastic hose usually requires a brass ferrell
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 05-03-2011, 09:05 PM   #5
jjtackleberry
that is brass....the connection to the back of the stock oil gauge requires that piece in the photo....the other end (on the block) uses a standard compression fitting......
Old 05-03-2011, 09:09 PM   #6
chevytruckluver
I can see that the pic is of a brass fitting, how will you use a plastic line with THAT brass fitting?
Trey
72 Short Step
Old 05-03-2011, 09:37 PM   #7
jjtackleberry
The same way I would the copper line....
feed it through and tighten the fitting
I'm only worried about it "cutting" the plastic...
The copper fitting "buldged/flared"
Old 05-03-2011, 09:46 PM   #8
chevytruckluver
Ok, now we are on the same page...I was thinking the same thing.
sorry for the confussion, I will try to let my brain engauge before I type next time. for what its worth, I stayed with copper on mine
Trey
72 Short Step
