Old 05-03-2011, 09:11 PM   #1
PRattenbury
What to do about my headers?
So a year or so ago when I had my engine apart I cleaned up my headers and shot them with silver header paint. But they didn't look good for very long. I guess the paint didn't stick very well and eventually started to flake off. So now the engine is out again, and the headers look like doo doo. Is there anything I can do with these things to keep them looking decent for a while? I am reluctant to change them for new ones because I'll cause myself more exhaust work. And new (good) headers are not cheap.
PRattenbury is offline   Reply With Quote
Old 05-03-2011, 09:49 PM   #2
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Re: What to do about my headers?
Get the right ceramic paint and cook them in an oven for an hour or two at 400* after painting them to properly cure them.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 05-03-2011, 09:52 PM   #3
Pop's C-10
Pop's C-10's Avatar
BBQ grill paint
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 05-03-2011, 09:52 PM   #4
PRattenbury
Who has the right ceramic paint?
Old 05-03-2011, 09:58 PM   #5
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
http://www.fordmuscleforums.com/exha...mic-paint.html
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 05-03-2011, 10:03 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
The best solution is to have the coated with a high temp ceramic coating. If thats not in your budget, bead blasting and spray bomb them with a premium high temp ceramic paint will work.
Oven baking is a great idea.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-03-2011, 10:38 PM   #7
f.monroe
f.monroe's Avatar
I used to paint every header I installed white . loved the way they stood out under the vehicle when viewed from the side . I sanded them down , painted them with VHT High Temp paint and heat cycled the headers several times to basically bake the paint . I would run the engine until the headers heated up and kill it . Let it cool and run it again a little longer and kill it again until they cooled down . Headers will cool fast . I did this several times then finally drove it normally . They would stay white for a long time and I only had to crawl under the truck and touch up the bottom of the headers on occasion . The top of the headers kept the paint for a long time .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 05-04-2011, 09:29 AM   #8
76stepsidechevy
That VHT header paint actually works well if you follow the instrustions, it can be baked in an oven or you can heat cycle the headers like frank said.
76stepsidechevy is offline   Reply With Quote
Old 05-04-2011, 05:53 PM   #9
PRattenbury
The powder coater I have used here locally in the past does ceramic coating. Maybe I'll ask him what he charges to sandblast and ceramic coat my headers.
Old 05-04-2011, 06:51 PM   #10
makman1297
makman1297's Avatar
TECH LINE COATINGS, INC, black satin header coating work very well, you need an airgun to apply it. I used it on my wifes motorcycle header pipe, which is a single layer pipe like a truck header over 3 years ago and has not flaked, baked, or fallen off. You just need to blast the pipe with glass bead first i believe, then spray on a thin coat, and install. I will scratch off if hit hard enough like your cars paint.
makman1297 is offline   Reply With Quote
Old 05-04-2011, 06:54 PM   #11
jrcaprai
http://www.jet-hot.com/
http://www.performancecoatings.com/index2.html
jrcaprai is offline   Reply With Quote
Old 05-04-2011, 07:18 PM   #12
3r!c84
Badass
3r!c84's Avatar
Originally Posted by jrcaprai View Post
here is mine jethot coated about 2 years ago.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-04-2011, 07:42 PM   #13
PRattenbury
That's the same color I'm trying to keep my headers. Those look good.
Old 05-04-2011, 10:46 PM   #14
DetroitDan
DetroitDan's Avatar
I bought some silver brush-on stuff from Eastwood years ago. Never got to use it, sold the 66 Caprice I bought it for. Think I've still got it somewhere but I dont know. Anyway I bought it because it sounded like it would work well. I never had much luck with anything out of an aerosol can.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 05-04-2011, 11:06 PM   #15
my4by2
my4by2's Avatar
Having them ceramic coated at a powder coater is not really that expensive a process & will last the life of the headers most likely. It'll be well worth too in order to reduce the under hood temps!!! None of the spray can coatings will be able to do this as efficiently...
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 05-05-2011, 12:53 AM   #16
72lb4x4
I haven't done it. Just throwing it out there...
"Anti Seize as a header coating. PICS"
http://www.nastyz28.com/forum/showthread.php?t=187500
72lb4x4 is offline   Reply With Quote
Old 05-05-2011, 01:17 AM   #17
y5mgisi
Second Chance Program
y5mgisi's Avatar
Holly Geesh! How the F have we not yet been introduced to that!
y5mgisi is offline   Reply With Quote
Old 05-05-2011, 08:07 AM   #18
sumran
sumran's Avatar
I use it on the exhaust nuts for my motorcycle. It stays in place until the next time I remove the nuts. It doesnt look that good, but I guess it is better than rust. It is dull. Looks like dried mud that is aluminum colored.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 05-05-2011, 09:47 AM   #19
wyattglock
wyattglock's Avatar
These guys did a friend of mine's headers and they turned out great. They can coat the inside and outside of the headers to improve flow and heat dissipation. Their prices arent bad either, but I know shipping could kill you unless you find someone local.
here is their site if you want to check them out.
www.prokoteindy.com
wyattglock is offline   Reply With Quote
Old 05-11-2011, 07:50 PM   #20
PRattenbury
Well, I dropped the headers off for ceramic coating today at lunch. We shall see what we shall see.
