Old 05-03-2011, 08:25 PM   #1
Vega
Steering stops
Going to use '73+ drop spindles on my "68. Can you use '71-'72 lower a-arms with the '73+ spindles without having any steering stop problems?
Thanks for you help.
Vega is offline   Reply With Quote
Old 05-04-2011, 12:19 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Steering stops
Originally Posted by Vega View Post
Going to use '73+ drop spindles on my "68. Can you use '71-'72 lower a-arms with the '73+ spindles without having any steering stop problems? Thanks for you help.
Yes you can.
I have done it before.
You will need to change the upper ball joint,... if,... your upper a-arms are from a '71 also.
The '71 lower ball joint will work fine with your 73-87 spindle.
Keith
Convert to disc brakes.
