05-03-2011, 06:21 PM | #1 |
Alternator amp/ air compressors
Just realized the early 70's & 80's alternators are only 40/50/60 amp alternators. I am going to run 2 viair 444c compressors that are 30 amp draw each. I have a red top optima battery. Will the alternator be enough or will I have to find a bigger one.
Get Low |
05-04-2011, 10:51 AM | #2 |
Happy to be here
Re: Alternator amp/ air compressors
If you are running two compressors in unison, I think you should update your alternator. I would consider any of the 90+ amp units on the market.
05-04-2011, 01:18 PM | #3 |
I called a friend of mine at an alternator shop. If any of you guys wanted to up grade to a bigger alternator. The part # that any parts store could cross would be 7294. It comes 94 amp, but your local alternator shop could get you up to 150 amps. This alterntor should be factory for 87-90 chevy trucks. I has to be the one with the solid plastic fan on the front. You learn something new everyday!
Get Low |
05-04-2011, 01:42 PM | #4 | |
