Old 05-04-2011, 09:14 PM   #1
southplainsag02
southplainsag02's Avatar
TH400 Transmission using Fluid...but where is it going???
I just recently purchased a 72C10. I believe it has the TH400 Transmission. When I pulled away from the place of purchase I added a quart of transmission fluid. I drove it at most 10 miles and it has been parked for 2 weeks while I tinker with it. Tonight I had to put in another quart to get the fluid to the correct level. There are no visual signs of leaks on my garage floor. Is this leaking around the transmission and then collecting dirt or what?
southplainsag02 is offline   Reply With Quote
Old 05-04-2011, 09:16 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: TH400 Transmission using Fluid...but where is it going???
wonder if the torque converter is full??...has the tranny been recently rebuilt???
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-04-2011, 09:30 PM   #3
hugger6933
could the vaccum modulator be the culprit? when they go bad the diaphram leaks and fluid is sucked into the intake manifold then burned by the engine. pull the vac. hose off see if it is wet in there or really soft and squishy. jim
hugger6933 is offline   Reply With Quote
Old 05-04-2011, 09:31 PM   #4
dave2953
Dave's not here, man
dave2953's Avatar
Possibly leaking from the transmission cooler into the cooling system?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 05-04-2011, 09:41 PM   #5
southplainsag02
The tranny has not been rebuilt for a long time. I will check the vacuum lines and see if that is it. There seems to be a lot of oil soaked dirt all around the transmission that could be soaking it up. Where would leaks form on a transmission except for around the pan?
Old 05-04-2011, 09:46 PM   #6
hugger6933
front seal ,rear seal ,around the dipstick[thats a bigge] speedo housing extension housing and of course the overflow in the top [breather]
Old 05-04-2011, 10:46 PM   #7
Tim R
Check the vaccuum modulator on the pass side probably diaphram busted sucking the fluid into the motor .It does it so slow it doesnt smoke but sucks the fluid out of the trans
Tim R is offline   Reply With Quote
Old 05-05-2011, 12:03 AM   #8
Gobbles
Gobbles's Avatar
Mine leaks out the tach cable, like a sieve mind you.
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 05-05-2011, 06:16 AM   #9
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Just putting this out there,...you did check the fluid level on hot idle? it may not really have needed the top up.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 05-05-2011, 07:13 AM   #10
MARKDTN
That's where I would start too.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-05-2011, 08:32 AM   #11
ubtripn
ubtripn's Avatar
I would check your radiator. I lost one 700R4 this way as stated above, the heat exchanger can go and mix the fluid, you keep pouring in tranny fluid and it disappears. If it's your heat exchanger your antifreeze/coolant will look like a brown/pinkish milkshake.
ubtripn is offline   Reply With Quote
Old 05-05-2011, 10:52 AM   #12
leddzepp
Moderator
leddzepp's Avatar
this is also my first question.
the truck is running and warmed up when you are checking the fluid, right?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-05-2011, 09:37 PM   #13
southplainsag02
The truck is definately warmed up and running. I will check the heat coolant when I get back and also look at the other things you guys mentioned. Thanks for all the help!
