Old 07-22-2003, 02:17 PM   #1
billsbowtie
billsbowtie's Avatar
need help ing.switch take out
can someone tell me how to take it out thanks bill
billsbowtie is offline   Reply With Quote
Old 07-22-2003, 03:12 PM   #2
barn9
Half a bubble off!
barn9's Avatar
Use a bent paperclip or something similar in the small hole to release the switch from the housing.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 07-22-2003, 03:58 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Insert said paper clip into the hole as you turn the key to the acc position. (counter clockwise) With a little wiggling and pulling, it should pop right out into your hand.
Old 07-22-2003, 04:18 PM   #4
Custom 68
Custom 68's Avatar
I know I know we have been through this before to no answer. The 68's dont turn CCW for the accessory position. What has anybody figured out on these?
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-22-2003, 04:29 PM   #5
Longhorn Man
No idea.
Old 07-23-2003, 12:31 PM   #6
billsbowtie
thanks for the help guys
i have 67/72 chevy truck parts f/s.
Old 07-23-2003, 12:48 PM   #7
Mark540
On 68's you put a paper clip in as instructed and turn counter clockwise about a quarter of an inch with the key installed and this will release the tumbler(there is no acc. position). You are physically moving the whole tumbler a quarter inch to get it past the tab which holds it in place. Works like a charm. Did it just the other day on a '68 ignition. If it won't budge try some penetrating oil around the edge of the tumbler, as some corrosion may have seized the tumbler in place. Good luck, Mark
1970 GMC Burb 4x4 - 68 Chevy Front, FI LT1, 4L60E
1970 Chevy Impala 47,000 miles
2001 BMW 540i 6-speed
2002 Dodge Ram 1500 4x4 w/20's
Mark540 is offline   Reply With Quote
Old 07-23-2003, 01:40 PM   #8
Custom 68
Custom 68's Avatar
Great Mark I will try it I hadnt spent much time working on it the post was up here a month or 2 ago without much success. I may try it tonight and will post the results.
Dave
Dave
