Old 07-21-2003, 10:50 AM   #1
Billy G
Billy G's Avatar
Steering wheel swap
Are there any 'tricks' to putting a '77 steering wheel on a '70?
The stock steering wheel is too big for the 'gravitationally challanged' individuals...*ME* @ 17.5". The '77 is 16"...not much help but with this one...if I cough...I wont send the truck in the ditch..hahah.
I'm assuming the column shafts are the same size and taper.
I'd really like some advice and/or comments on this...and as always ...any and all are greatly appreciated.
Billy G
My FAMOUS LAST WORDS...."Ima Gonna!!"
- 1970 GMC 1500 swb/step 250 I-6 3 spd - "The GEM"
- 1976 Chev Scotsdale swb/step 350/350 - "The JEWEL"
- 1982 Chev C-10 swb/step 250 I-6 3 spd -
- 2001 Chev Silverado LT -
Billy G is offline   Reply With Quote
Old 07-21-2003, 11:01 AM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
It's a direct bolt on, shaft diameter and sline count is the same
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 07-21-2003, 07:12 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You'd be even better off getting one off of a later truck or blazer. I think they may be 15 inch, and they are padded, adn IMO, look much better than the '77 wheel.
Old 07-21-2003, 09:04 PM   #4
Huck
Huck's Avatar
Can you spell "tilt"? If you go with a later model wheel up to around 95, they are not air bagged and come in a lot of different configs---2,3,4 spoke wheels. Think it through as some have lower spokes that block your lower gauges. I went to a tilt column out of a Van and a steering wheel out of a Corvette. Works out with my challenged horizontal verses vertical measurements (----)Huck
Huck is offline   Reply With Quote
Old 07-21-2003, 10:59 PM   #5
racedvl
racedvl's Avatar
I love my wheel, just needs a little modifaction with the turn signal cancel cam.
racedvl is offline   Reply With Quote
Old 07-21-2003, 11:35 PM   #6
busterwivell
Racedvl has the same one I do, I love it!
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 07-22-2003, 12:16 AM   #7
jjk3
It's just a check engine lamp.
jjk3's Avatar
Billy G--Hows the engine in the GMC doing? Did you get the pics I sent you?
racedvl--What's the story with Yoda?
Active Inliner---bigchevy66
68 SWB Stepside 250 L6/3 on the floor/ Hedman headers, HEI, MSD 6A box, K&N filter, Offy intake and Edelbrock 600cfm 4 barrel
Soon to have: WC T-5 five speed
66 SWB Stepside-undergoing restoration
jjk3 is offline   Reply With Quote
Old 07-22-2003, 05:29 PM   #8
Billy G
Billy G's Avatar
hiyaz JJK....engine is running better...im STILL having 'idle' problems....can NOT seem to get this carb to idle down. Once I get that...I can get a better mixture...ect. Other than that...running GREAT! Jason liked that pic with the carbs...lol...said ...I want that!...I said.....GET A JOB!!!!
so much for THAT...hahahah
Billy G
Old 07-22-2003, 05:49 PM   #9
Slams_58
I put a Grant GT in mine. DAMN forgot to switch screens!!!
Slams_58 is offline   Reply With Quote
Old 07-22-2003, 11:16 PM   #10
jjk3
jjk3's Avatar
Billy G--What are you ideling at? I'm sure you've already adjusted the idle screw on the upper side of the carb. Is all you linkage moving freely? Is the choke plate wide open? Just some simple stuff I usually overlook. Let me know if you need anymore pics.
I've got the same steering wheel as dubie does. I want another one that's larger, but I'm 6'4" and I don't think it will work out too well. I don't have power steering either, but at least I'm building muscles this way.
