Old 05-07-2011, 03:24 PM   #1
Pop's C-10
Pop's C-10's Avatar
Re: How low can I go?
For a grand..you could be able to go with a heavy static drop in tha back & bag tha front..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 05-07-2011, 04:27 PM   #2
SCOTI
SCOTI's Avatar
Why the recommendation for static/back & bags/front?
Unless you're removing the front fenderwells, the only thing bags will net you is an extra inch of drop when parked (although the extra lift would make it easier putting a floor-jack under it ).
Trimming 1-coil of the stock springs & 3" spindles will get it to to the point of buzzing the tops of the fenderwells w/a 27" tall front tire on moderate dips in the road. A good set of shocks, decent alignment, & it's done w/o the cost for air.
Now, just cutting coils or all the drop from just shorter aftermarket coils & not using spindles would ride much worse vs the shorter air bag.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
