Old 05-07-2011, 09:44 PM   #1
sinnersahuayo
i have a 65 c10 v8
what transmission would ber a bolt on transmission with OD. please give year and brand of car.
sinnersahuayo is offline   Reply With Quote
Old 05-07-2011, 10:14 PM   #2
jocko
jocko's Avatar
Re: i have a 65 c10 v8
You didn't mention if you want a manual or automatic trans. If you currently have a manual, the you'll have most of the parts to add another manual with o/d. If you don't then you'd need to source the pedals, Z-bar, clutch linkage, bell housing, etc etc.
Anyway,
If you want an Automatic Trans:
From a Chevrolet (so bell housing bolt pattern matches):
- 700R4
- 2004R
Both of which will need a torque converter lock-up kit
Or:
- 4L60E/4L65E
- 4L70E
- 4L80E/4L85E
- 5L40E/5L50E
All of which will need an electronic shift controller
If you want a Manual Trans:
T5 (recommend the World Class version)
TKO 500/600
M-21Y
Keisler RS400/500/600
Old 05-07-2011, 10:16 PM   #3
sinnersahuayo
Anyway,
- 700R4
- 2004R
Or:
- 4L60E/4L65E
- 4L70E
- 4L80E/4L85E
- 5L40E/5L50E
TKO 500/600
M-21Y
your right sorry about that i have a manual thank you.
Old 05-07-2011, 11:47 PM   #4
Captainfab
60-66 Nut
What engine do you have in your truck and aprox HP and TQ. Do you plan to use it as a truck or is it a cruiser/fun truck?
Old 05-08-2011, 11:28 AM   #5
sinnersahuayo
like everybody a daily driver and when need a fun. the hp is aorund 300 hp same with the tq.
Old 05-09-2011, 12:06 AM   #6
Captainfab
60-66 Nut
Well then if you're looking for a 5 speed manual trans, you could use a T5 or a NV3500. I do know that the NV3500 is rated at 330 ftlbs. The T5 came in 3rd Gen F-body's as well as S-10's and the NV3500 came in '88 and up full size trucks.
Old 05-09-2011, 02:12 AM   #7
sinnersahuayo
the bell housing, flywheel, trans mount, and yuke would fit or i have to mod it
Old 05-10-2011, 12:36 AM   #8
Captainfab
60-66 Nut
Which trans?
There is a good thread over in the 'Engine and Drivetrain' section, with lots of info on a T5 conversion.
http://67-72chevytrucks.com/vboard/s...d.php?t=313954
The NV3500 has an integral bellhousing, and is only a hydraulicly actuated clutch. What flywheel will depend on what engine you have. For a trans crossmember, you will just need one from a '63-'87 2wd pickup or Suburban with an auto trans, or possible from a '73-'87 with a manual trans. The yoke will need to be specific for the trans used, but you may need a conversion U-joint to mate that to your driveshaft.
