Old 05-07-2011, 05:17 PM   #1
7111127
Question on a 1970 GMC Buckets Seats Install?
i have a 1970 gmc i wanna put bucket seats in what is the best way
is there a truck with seats i just pull them out and put in or do i need 2 just buy some aftermarket seats and make them fit?
7111127 is offline   Reply With Quote
Old 05-08-2011, 03:51 PM   #2
Liz
Catchy title goes here..
Liz's Avatar
Re: i dont know where to post this ?
moved to the 7-72 message area for you.
Liz is offline   Reply With Quote
Old 05-08-2011, 05:22 PM   #3
Autoblueprint
Autoblueprint's Avatar
Re: i dont know where to post this ? BUCKET SEATS
This will get you started:
http://www.autoblueprint.com/1971_pa..._photopg1.html
It's like 7 pages...but it chronicles the interior change I did to my 71 C-10 using Wiseguy's bucket seats.
Hope this helps.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 05-08-2011, 05:27 PM   #4
70cst
70cst's Avatar
Re: Question on a 1970 GMC Buckets Seats Install?
I changed your heading to help you out...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-08-2011, 06:33 PM   #5
mikey531
mikey531's Avatar
Re: Question on a 1970 GMC Buckets SSeats Install?
This is what I did :
http://67-72chevytrucks.com/vboard/s...d.php?t=368266
mikey531 is offline   Reply With Quote
Old 05-08-2011, 10:54 PM   #6
7111127
what brackets could i buy that would really close 2 mounting
Old 05-09-2011, 05:57 AM   #7
mikey531
mikey531's Avatar
The brackets are on the seat, just drill new holes and plug the old ones. The seats just bolt in, it is real easy.
Old 05-09-2011, 07:01 AM   #8
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Morning Mike
I put BMW buckets in my truck and wanted them low ..I stripped them down to the tracks cut a piece of 1/4"x2" flat stock...fitted the plates to the stock holes in the floor, just lay them over the factory holes with some weight on top then went under the truck with a sharpie and poked though the holes to mark the plates...my plates go across the truck...drilled out the holes and dropped in a bolt in each corner...placed the seat in the truck and sat in them to find a comfy placement that allows track movement front to back..marked the holes on the plate..took everything out drilled the plates for the seat and bolt them onto the seat..throw the hole thing back in the truck and bolt back into the factory holes....
It was easy and this way there is no fussing with extra holes or plating new bolt holes,Plus if I ever want to put the stock seat back in it will take 10 min or for that matter any other seat
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-09-2011, 02:00 PM   #9
7111127
Originally Posted by Hottrucks View Post
Morning Mike
that idea i like lol i didnt want 2 drill holes in 2 the floor of the truck
