Old 04-17-2011, 01:02 PM   #1
albertarose
albertarose's Avatar
72 Blazer need advice on door boo boo fix
Hello thanks for reading ! I have a 72 blazer in decent shape , well it was LOL
the drivers door got pulled open too far and of course the hinges are now sprung and the door has a wrinkle where it tangled with the fender which actually looks to be not damaged .. I guess the first thing to try is replacing the hinges ..which brings my question ..are blazer hinges different from truck hinges ? ..I can post pics if it helps ..I just want to say always be sure your door is latched when moving your rig ..especially on a very windy day !i will consider myself lucky if changing only the hinges fixes this ..I am looking for a new door just in case but im sure the door is totally different from truck door ? anyone ? thanks Leon
albertarose is offline   Reply With Quote
Old 05-09-2011, 03:57 PM   #2
bundeber
Re: 72 Blazer need advice on door boo boo fix
You can use a truck door. You need to cut the top off and weld a plug on it, and then remove the rear of the post where it connects into the back of the door. Use your blazer door as reference. But the doors and I believe the hinges are identical.
bundeber is offline   Reply With Quote
Old 05-09-2011, 06:11 PM   #3
jaros44sr
jaros44sr's Avatar
^^^^I agree, but also take out the stiffner plate from the blazer door and use it
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
