Java Mechanic
Frankenstien's Lawnmower
There won't be much to show until saturday but....
Yesterday afternoon I was mowing the lawn. I got through the neighbor's back yard (she puts up with our redneck ways and works wierd hours as a nurse so I mow her back yard as a neighberly thing) and about half of my back yard when my old hand-me-down, Wally-world yardman tractor siezed. I know it's right dead because it made a right ugly noise when it died and it is frozen solid. :P In my shed I also have a Simplicity mower with a good motor and a bad transmission. Sounds like I have all the ingrediants to get one working mower out of this, though it's going to be far from a bolt-in swap to replace the 12hp motor with the 16hp twin from the Simplicity tractor. I'll takes lots of pictures and document it, suceed or fail... should be a hoot either way.
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
Java Mechanic
Re: Frankenstien's Lawnmower
Here is what I starting with -- the one with the broken motor:
Java Mechanic
Now... the one with the good motor and the wonky trans:
Java Mechanic
The 16hp B&S twin is a larger engine (in all respects) than the 12.5 B&S I'm replacing so there is going to be some finageling required here. I'm going to start Saturday morning because it's fixin to rain buckets tomorrow.
Java Mechanic
I don't have a V6 to put in it... :P
Java Mechanic
Got a lot done on it... between the rain and my back I'm gonna give it a rest for today and watch some NASCAR. lol
Got the dead motor out of the little mower.
Java Mechanic
Got my tools on the custom bench
Java Mechanic
Here is the hill in my back yard (it's why I can't live without a ride on!) and you can see where I was when it died! lol
Java Mechanic
Got the good motor out of the big mower (the one with the bad trans) and verified that the drive pulley fits (would have been game over if the drive pulley couldn't be swapped between them.)
I set the motor on the front of the motor. It will bolt up but I'll need to modify the exhaust because it interfers with the steering and since the carb is on the front of the twin instead of the side I'll need to do some custom work to get all the controls hooked up. Nothing that looks un-doable so far. I'll get back to it in the morning.
I only have slight small engine experience, but on the one I played with the exhaust opening on the head was threaded, so I put some threaded pipe thread on to get the muffler out a little ways. Maybe an option for you??
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
The One And Only !!!
MTD actually built that style unit with 16 up to 20 hp engines. The only wire you won't need is the one for the old fuel cut-off solenoid on the carb.
Check for one of those mufflers.... From my dealer's parts look-up for a 98/99 machine; ![]()
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
the boat guy
mufflers?! It's frankenmower! Frankenmower needs 4" stacks! And some spinning hubcaps.....
I did run straight black iron pipes all the way out the back of a old twin Sears GT I once had.... ![]()
#15 |
Java Mechanic
I was looking briefly at the solonoid -- do I need to jump it to the ingition wire or just leave it without hooking it up?
Maybe I should plumb the exhaust out the back and run a 6" mufler like the kids do on the Civics around here... lol
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... Last edited by panhandler62; 04-23-2011 at 07:34 PM. |
#16 |
That's all, Or you can cut it up closer to the harness and tape the wire up. That would be less un-needed wire hanging around.
Believe it or not the 16 I straight piped wasn't all that loud, It had more a low tone rumble to it ! hehe After seeing the Tool Time episode shown above years ago, I jumped on the Mow Power band wagon and put a 12.5 Briggs on a 20" MTD push mower. It sat in our showroom for close to 8 yrs till someone wanted to buy the engine..... ![]()
#17 |
Java Mechanic
Almost got it.. have some sort of a fuel problem with the 16 though. It sat in the shed for a couple years. It fires right up and runs if you shoot ether in it or dump a little gas down it but it shuts down when it runs out.
Getting gas to the carb but it doesn't seem to be getting any *in* the carb.
#18 |
Java Mechanic
OK.. figured that out. Just needed to feed a switched 12v to the fuel cutoff solenoid. All that's left is to put the grill and hood back on and mow the dang grass!
#19 |
You're going to need the extra horse power to cut that stuff.
#20 |
Java Mechanic
Frankenmower lives!
Rebuilt the carb today and it runs great now. Many, many thanks to Restrorob!
#21 |
Glad to help out on FRANKENMOWER !!!
#22 |
![]() Join Date: Aug 2008
"After" photos!
#23 |
Java Mechanic
OK... lol.... I'll take some when I roll it out this weekend to mow. Nothing real exciting, just a little rider with a much bigger motor than the factory installed. lol
(do I have to grunt like Tim Allen now?)
#24 |
Naaa.....You can wait till ya post the pics ! ![]()
#25 |
Java Mechanic
uggghhhhhhh-ahhhh!
