05-07-2011, 09:44 PM | #1 |
i have a 65 c10 v8
what transmission would ber a bolt on transmission with OD. please give year and brand of car.
05-07-2011, 10:14 PM | #2 |
Re: i have a 65 c10 v8
You didn't mention if you want a manual or automatic trans. If you currently have a manual, the you'll have most of the parts to add another manual with o/d. If you don't then you'd need to source the pedals, Z-bar, clutch linkage, bell housing, etc etc.
Anyway, If you want an Automatic Trans: From a Chevrolet (so bell housing bolt pattern matches): - 700R4 - 2004R Both of which will need a torque converter lock-up kit Or: - 4L60E/4L65E - 4L70E - 4L80E/4L85E - 5L40E/5L50E All of which will need an electronic shift controller If you want a Manual Trans: T5 (recommend the World Class version) TKO 500/600 M-21Y Keisler RS400/500/600 |
05-07-2011, 10:16 PM | #3 | |
05-07-2011, 11:47 PM | #4 |
60-66 Nut
What engine do you have in your truck and aprox HP and TQ. Do you plan to use it as a truck or is it a cruiser/fun truck?
05-08-2011, 11:28 AM | #5 |
05-09-2011, 12:06 AM | #6 |
60-66 Nut
Well then if you're looking for a 5 speed manual trans, you could use a T5 or a NV3500. I do know that the NV3500 is rated at 330 ftlbs. The T5 came in 3rd Gen F-body's as well as S-10's and the NV3500 came in '88 and up full size trucks.
05-09-2011, 02:12 AM | #7 |
the bell housing, flywheel, trans mount, and yuke would fit or i have to mod it
05-10-2011, 12:36 AM | #8 |
60-66 Nut
Which trans?
There is a good thread over in the 'Engine and Drivetrain' section, with lots of info on a T5 conversion. http://67-72chevytrucks.com/vboard/s...d.php?t=313954 The NV3500 has an integral bellhousing, and is only a hydraulicly actuated clutch. What flywheel will depend on what engine you have. For a trans crossmember, you will just need one from a '63-'87 2wd pickup or Suburban with an auto trans, or possible from a '73-'87 with a manual trans. The yoke will need to be specific for the trans used, but you may need a conversion U-joint to mate that to your driveshaft.
