Old 05-10-2011, 02:59 PM   #1
Mrtn15
Mrtn15's Avatar
My RPM's are too high!
Crusing down the highway, my rpm's are at about 3000! It's just a 350 motor and 350 trans with a shift kit! Te drop down cable doesn't work! Amd it has a lockup convertor! It ran like 2450 at 70 before my trans rebuild!!! Stock rearend!
1986 Single cab 2WD Chevy 350/350
1977 Single cab Dually C30 BB454!
Mrtn15 is offline   Reply With Quote
Old 05-10-2011, 10:22 PM   #2
rayfinseats
Re: My RPM's are too high!
Is it going into high gear or staying in second? Count the shifts.
rayfinseats is offline   Reply With Quote
Old 05-10-2011, 10:33 PM   #3
Mrtn15
Mrtn15's Avatar
Ita going into third ! I also just got it rebuilt
Old 05-10-2011, 11:59 PM   #4
SCOTI
SCOTI's Avatar
What transmission is it?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-11-2011, 12:03 AM   #5
Mrtn15
Mrtn15's Avatar
Th350
Old 05-11-2011, 12:18 AM   #6
SCOTI
SCOTI's Avatar
The convertor locking up will get some RPM reduction, but it won't get 600rpm worth. The kickdown cable not working is where I would start. Find out why it's not working.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-11-2011, 12:20 AM   #7
Mrtn15
Mrtn15's Avatar
Okay! Thanks for helping! I will see what's wrong with my convertor!
Old 05-11-2011, 12:26 AM   #8
SCOTI
SCOTI's Avatar
And kick-down cable....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-11-2011, 12:27 AM   #9
Mrtn15
Mrtn15's Avatar
Well yeah! Haha that too! That's first!
Old 05-11-2011, 03:49 PM   #10
76stepsidechevy
What does the truck have for gears and what size tires are you running?
76stepsidechevy is offline   Reply With Quote
Old 05-11-2011, 03:50 PM   #11
Mrtn15
Mrtn15's Avatar
275/60/15 and stock gears idk lol
Old 05-11-2011, 04:14 PM   #12
3r!c84
Badass
3r!c84's Avatar
thats pretty normal. th350 do NOT have a over drive. only 3 gears. the kick down cable has nothing to do with driving. it only for what the name employs. kick down. down shift.
ive got a shorter tire. 25.5 inch tall. with only 3:42 gears im doing 65 on the highway at 3k.. if you want do drop your rpm's go with a 700r4. its a over drive tranny.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-11-2011, 04:33 PM   #13
SCOTI
SCOTI's Avatar
It should remain what it was prior to being rebuilt....
....It ran like 2450 at 70 before my trans rebuild!!!
Unless the trans was swapped from an OD unit to a 3spd.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-11-2011, 08:54 PM   #14
76stepsidechevy
how the new trans feel and how does the fluid look ? could it possibly be slipping ?
Old 05-11-2011, 08:59 PM   #15
broey
Square
broey's Avatar
vacuum leak will do it too.
Squarebody Syndicate
broey is offline   Reply With Quote
