#251 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: How to: Ruin a perfectly good C10
Gringoloco,... I have a repair panel for the "visor area" of your cab, that I don't need,... if you are interested.
Like this one: http://www.topbananaparts.com/servle...y-inner/Detail
#252 |
Big Red - Now its a SWB!
Ouch, Gotta hate those hidden gremlins!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#253 | |
A guy with a truck
Wheeeeeee!!! Actually, it's not too bad- I've definitely seen worse- it's just that it was so easily preventable...
Meh, no biggie. I knew the visor rust was there and had a good idea there would be some surprises behind the windshield gasket. Quote:
![]() Yup- just glad it wasn't worse ![]()
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#254 |
A guy with a truck
Well, after removing the offending metal and cleaning up any signs of any sort of rust, then liberally coating it with rust inhibitor, I set to work on trimming the patch panel to fit. This little project is anti-fun. Between working overhead and the compound curvature of the area, it becomes an extreme pain to install the patch. After MUCH trimming, fitting, trimming, fitting, trimming, and fitting, I finally got it tacked-in place and looking decent. Did I mention, "what a pain"?
#255 |
Man,... you do good work!
#256 |
VA72C10
![]() Join Date: Mar 2008
very nicely done!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#257 |
A guy with a truck
Thanks fellas! It's not perfect, but waaay better than before...
#258 |
Still Learning
Wow! nice work on the rust repair! I love the PO conversation. No matter what year model bed they change it too, the original always looks better. Not a fan of interchanging beds unless it's 67-72. It's hard to believe that some shops do the things they do.
#259 |
Sofa King Crazy!!
^^ x2
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#260 | |
A guy with a truck
#261 |
A guy with a truck
Today I managed to get a patch cut, formed, and welded in for the gaping hole in the windshield frame. Once this was in, I applied liberal amounts of seam sealer to the four windshield seams, as well as a few other areas that were in need of some sealant. Also finished welding the visor area patch (you can clearly see the relief cut I had to make to get the curves to align properly), spent a BUNCH of time grinding it smooth, then applied some epoxy primer. A skim coat of filler and it will be ready for some color
#262 |
Man of Mini-Talents
Impressive - and quick too. An average body man would have milked that for a few weeks.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#263 |
Wow! I have the same harbor freight gun and I could not get it to lay down that good as a matter of fact it ruined all my previous prep work!! Congrats on the success, what brand of paint are you using? Do you have any painting advice? I'm in the middle of rebuilding my 99 silverado after I rolled it and all that's left is paint.
Liking the build though it looks great keep up the good work Posted via Mobile Device |
#264 | ||
A guy with a truck
![]() Quote:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 05-10-2011 at 11:20 PM. |
#265 |
Sofa King Crazy!!
That really came out great!
#266 |
![]() Join Date: Dec 2006
Wow, nice job looks great
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#267 |
Much nicer looking now.
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
#268 |
A guy with a truck
Thanks all!
#269 |
Just read through your build, SWEEEEEEEEEET!!!!!!!!!!!
I hope i can ruin my truck half as nice. Eric
69 chevy stepside (project) ![]() 2006 Silverado Z71 Ext. cab ![]() 2005 Saturn VUE (wifes dd) |
#270 | |
A guy with a truck
#271 |
A guy with a truck
So, the day started out not so great, as the epoxy primer I shot yesterday decided not to cure. Instead of being a nice, hard surface to start body work on, I had a gummy mess. I spent the better part of the morning cleaning that up and making a run to the paint store. Once that was out of the way, I started the body work on the visor area, and got it in a coat of poly primer for final wet-sanding before color...
While I was waiting for primer to dry, I got the bedside braces in- they had to be dropped the same amount as the 'body lift'- don't worry, I'll clean them up and paint them... I also used the extra body filler and primer from the visor area to do a little work on the bedside splice. It will require a little more work before paint, but is most of the way there ![]()
#272 |
A guy with a truck
...and since the visor area was ready for paint, I decided to go ahead and shoot it
![]() Also got the clear sprayed. It did not lay down perfectly, partly due to shooting upside-down, mostly due to me being in a hurry, but that's ok, as it matches the rest of the orange peel ![]()
#273 |
Awesome
This encourages me to go get started on my build....which is in the garage looking at me right now Posted via Mobile Device
Best Regards, Leon 1970 C/10 LWB Cummins Turbo - Build in Progress Many other toys as well... |
#274 | |
A guy with a truck
#275 |
67cheby
![]() Join Date: Sep 2008
HOLY SMOKES.....your going so fast your making me DIZZY !!
