My RPM's are too high!
Crusing down the highway, my rpm's are at about 3000! It's just a 350 motor and 350 trans with a shift kit! Te drop down cable doesn't work! Amd it has a lockup convertor! It ran like 2450 at 70 before my trans rebuild!!! Stock rearend!
Re: My RPM's are too high!
Is it going into high gear or staying in second? Count the shifts.
Ita going into third ! I also just got it rebuilt
What transmission is it?
Th350
The convertor locking up will get some RPM reduction, but it won't get 600rpm worth. The kickdown cable not working is where I would start. Find out why it's not working.
Okay! Thanks for helping! I will see what's wrong with my convertor!
And kick-down cable....
Well yeah! Haha that too! That's first!
What does the truck have for gears and what size tires are you running?
275/60/15 and stock gears idk lol
Badass
thats pretty normal. th350 do NOT have a over drive. only 3 gears. the kick down cable has nothing to do with driving. it only for what the name employs. kick down. down shift.
ive got a shorter tire. 25.5 inch tall. with only 3:42 gears im doing 65 on the highway at 3k.. if you want do drop your rpm's go with a 700r4. its a over drive tranny.
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
#13 | ||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-11-2011 at 04:34 PM. |
how the new trans feel and how does the fluid look ? could it possibly be slipping ?
#15 |
Square
vacuum leak will do it too.
Squarebody Syndicate |
