Old 12-14-2010, 10:15 PM   #1
themb2g
LS1/LS2 Conversion with 4x4
I am planning on converting my 72 blazer to either an LS1 or LS2 engine but I am finding no threads on doing this and keeping it 4x4. What do you do with the transfer case,etc. Can anyone guide me in the right direction with transmission and transfer case answers. thanks!
themb2g is offline   Reply With Quote
Old 12-15-2010, 10:56 AM   #2
Burt4x4
Burt4x4's Avatar
Re: LS1/LS2 Conversion with 4x4
My buddy runs a LS2 in his 72. He is allways swapping Auto to Manual and back...depends on what he is using the truck for..Pismo he uses the Auto and rock crawling he uses the manual.
THey are kinda far from you but pacificfab.net in Morgan Hill CA has all the knowledge you need for the swap.
Or Google LS2 K5...?
.02c good luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 12-17-2010, 04:34 PM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
Might be able to swap a ford or dodge D44 axle under the front so that the late model TC case drop lines up with the pig on the front axle?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-17-2010, 05:21 PM   #4
edflores
You dont do anything if you dont want to. My boss link his LS1 to his already stout 350/np205 combo. Someone makes an engine Xmember that he used, and crossover steering.
edflores is offline   Reply With Quote
Old 12-17-2010, 10:07 PM   #5
Ronnie Mehling
I am building mine right now i used ls1 with 4l80 and the stock np205 i had to use a advanced adapter to join the tranny with the np205
Ronnie Mehling is offline   Reply With Quote
Old 12-18-2010, 03:07 AM   #6
themb2g
That is incredibly helpful. Thanks!
Old 03-31-2011, 05:04 PM   #7
jstplyn331
jstplyn331's Avatar
what Crossmember was used to put the LS-1 in? I have had a hard time trying to find a 4 wheel application for the LS-1 in a 4 wheel drive.
Any advice will be great
Build Thread,
jstplyn331 is offline   Reply With Quote
Old 03-31-2011, 10:53 PM   #8
notorious
looks amazing
notorious is offline   Reply With Quote
Old 04-02-2011, 02:22 AM   #9
mcmlxix
Collector of Projects
mcmlxix's Avatar
Did you start with a 4x2 or 4x4 4L80e transmission?
Rich
1972 K5 Blazer CST Click HERE
Old 05-04-2011, 04:13 AM   #10
67GMC3/4
novak trans adapters has what you need to run a numerous selection of auto and manual transmissions. http://www.novak-adapt.com/ , I am also thinking of doing the swap with an ls1 out of a c5. i want a good all around truck, I have an SM420 4 speed in it that I could make work but dont know if it will hold up you familiar with that trans ?
67GMC3/4 is offline   Reply With Quote
Old 05-04-2011, 06:52 AM   #11
jstplyn331
jstplyn331's Avatar
From all I can see on Novaks web site is stuff for Jeep conversion. Have you actually found something for the LS1 into a chevy truck/Blazer the look to have mounts and crossmembers for the LS1 but the applications are for a jeep? Let me know if you could I appreciate it.
Build Thread,
Old 05-08-2011, 07:22 PM   #12
ZZ4
Check out advanceadapters.com
ZZ4 is offline   Reply With Quote
Old 05-08-2011, 09:20 PM   #13
72truckman
72truckman's Avatar
LS1 is the same as a 5.3, 6.0 etc they are all vortec engines and hook up the smae mechanically. check out my blazers thread in my signature should help u out
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
****SOLD!!!!!**** 1965 GMC 4X4
http://67-72chevytrucks.com/vboard/s...d.php?t=294727
72truckman is offline   Reply With Quote
Old 05-08-2011, 09:37 PM   #14
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
More info in my sig.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 05-09-2011, 09:38 AM   #15
fun in dirt
fun in dirt's Avatar
Are there any problems with mud/water splashing all over these motors and the wiring?
That is the only real concern I have about running one of these.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 05-11-2011, 10:19 AM   #16
niceguy678us
No problems with water. All the wiring connectors are weather pack. Mount the ECU high and dry under the dash and build a breather box that aquires air from a high/dry point (like a snorkle) and you can submerge the whole thing if necessary LOL.
Check out my build thread.
1970 Datsun 240Z
1972 K5 Blazer Highlander
1972 Chevelle
1959 Apache 3100 SWB Fleetside
2006 VTX 1800f
Build thread:
http://67-72chevytrucks.com/vboard/s...ght=highlander
niceguy678us is offline   Reply With Quote
