Old 05-09-2011, 08:21 PM   #1
bigguy69
dazed and confused
bigguy69's Avatar
running hot
i have had a problem with my truck running a little to warm. it is a 350 with a 3 core radiator. going down the interstate it will run about 220 degrees. i have replaced the thermostat, cleaned the radiator, replaced the bottom hose. now i noticed that the new hose didnt have the spring in it. the guy behind the counter said that it didnt need it. but when it is warmed up the bottom hose will suck in. i think this might be my problem. does anybody sell a hose that has the spring in it? or am i missing something? it does not run hot in town about 195. any suggestions? thanks in advance.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 05-09-2011, 08:30 PM   #2
umwtnt
umwtnt's Avatar
Re: running hot
Do you have a fan shroud. Normally the fan is so far away from the fan that the engine will not cool properly without it. Also does the hose suck in when the engine is running or after it is shut down? If is after shut down then the radiator cap is bad. Good Luck.
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 05-09-2011, 08:40 PM   #3
bigguy69
dazed and confused
bigguy69's Avatar
Re: running hot
It has 2 electric fans on it. It sucks the hose in while it is running. Almost flat.
Old 05-09-2011, 08:49 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: running hot
Run to another auto parts store and get rid of your lower radiator hose that you have!!! That's not normal.
Also, you might look into getting a cap that you can use with an overflow tube or reservoir. Mine ran somewhat hotter than I liked and I installed a small overflow container made with 3" pvc pipe. Now it stays at 185 even in the hottest 100 plus Texas days.
Another plus, I don't lose any coolant.
68gmsee is offline   Reply With Quote
Old 05-09-2011, 09:02 PM   #5
cdowns
cdowns's Avatar
Re: running hot
try taking the actual tempature of the coolant with a know good thermometer to see if in fact there is a temp problem b4 throwin money at it is my normal warning
Old 05-09-2011, 09:07 PM   #6
bigguy69
dazed and confused
bigguy69's Avatar
Re: running hot
Thanks for the help guys. I guess I have got some mechanical work to do!
Old 05-09-2011, 10:05 PM   #7
geezer#99
geezer#99's Avatar
Re: running hot
Keep your bottom hose and make your own coil for inside it.
I made mine out of 14 gauge galvanized wire. Wrapped it around a 1and 1/2 inch pipe to make a coil. Bought the wire at the hardware store.
Easy-Peazy!!!
geezer#99 is online now   Reply With Quote
Old 05-09-2011, 11:44 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: running hot
running hot at freeway speeds generally indicates a coolant flow issue since you have a ton of fresh air blowing through the rad (assuming you don't have a million leaves and chicken feathers blocking airflow). Your lower hose going flat with engine RPMs is a problem, and a good place to start. Most modern hoses don't need that spring, but where ever you got that hose... I wouldn't buy another one there(or that brand)
Old 05-09-2011, 11:51 PM   #9
Dark Knight
Dark Knight's Avatar
Re: running hot
Personally, I hate the look of radiator hoses. They're just so...ugly. I was thinking of getting some copper pipe and soldering some ends onto it and making my own tubing that I could just slip a small section of hose onto the end of and using that. Then, I have a hard line, and no collapses. Plus, I could solder a draincock onto the lower one as an added bonus. I suppose I'd have to flare the ends though to keep the hose from blowing off.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 05-09-2011, 11:52 PM   #10
Dark Knight
Re: running hot
^^^^Chicken feathers? lol. I live on the farm and still don't have that problem.
Old 05-10-2011, 12:05 AM   #11
Longhorn Man
Re: running hot
you probably wouldn't need to flair anything... most rads don't have anything on them, just straight pipe. 4X4 trucks 67 - 72 had a steel pipe in place of the solid upper rad hose.
I've seen chicken feathers clogging 2 rads, once was an old 70 1/2 camaro, and the other one was a columbus police car (9c1 caprice).
The cop car was 4 years ago, and I am STILL trying to figure that one out.
Old 05-10-2011, 01:19 AM   #12
DesertCat
DesertCat's Avatar
Re: running hot
Exactly right, coolant flow problem.
One thing I always do when I get a cooling problem is check the oil for chocolate milkshake. If you have that then you get to change head gaskets, at least... don't ask how I know this...
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 05-10-2011, 10:37 AM   #13
68gmsee
Active Member
68gmsee's Avatar
Re: running hot
.......I've seen chicken feathers clogging 2 rads, once was an old 70 1/2 camaro, and the other one was a columbus police car (9c1 caprice). The cop car was 4 years ago, and I am STILL trying to figure that one out.
About 4-5 yrs ago wife and I were traveling through Georgia on I-20 behind a several 18 wheelers carrying chickens in crates doing about 70-80 mph. We had to stay behind a mile or so cause feathers were flying off the chickens and about every 5 miles or so, a chicken would fall out and splatter on the road and cars were sucking up the feathers. Honest truth...
Old 05-10-2011, 11:07 AM   #14
bigguy69
dazed and confused
bigguy69's Avatar
Re: running hot
I did wash the rad out. I didn't see no chicken feathers. . But I did see alot of bugs though. I am curious about the cop car myself.
Old 05-10-2011, 04:39 PM   #15
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: running hot
Maybe this will help!!
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-11-2011, 10:46 AM   #16
68 IRON
68 IRON's Avatar
Re: running hot
This would be easy to do, direct reading. Use either laser style or even a meat thermometer. You may find (like I did) the gage is reading high. Bottom line though is to confirm you are indeed reaching those temps.
68 IRON is offline   Reply With Quote
Old 05-11-2011, 10:57 AM   #17
68gmsee
Active Member
68gmsee's Avatar
Re: running hot
His bottom radiator hose is flattening out. He needs to fix that first.
Old 05-11-2011, 11:18 AM   #18
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: running hot
Is the radiator the original 40 year old 3 row? The water pump might be trying to suck water from the bottom with limited flow in the radiator. Which might be collapsing the lower hose. You might need to have the radiator rodded out or replaced if there is too much crud in the core.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-11-2011, 11:59 AM   #19
68 IRON
68 IRON's Avatar
Re: running hot
This is true, you are correct sir! How about this...Drain the cooling system, disconnect the upper radiator hose from the radiator and secure away to drain on the ground. Feed the radiator using a garden hose with cool water (like you would do with an outboard motor). If the radiator chambers are on the side, you will have free flow to the pump. If the chambers are top and bottom, this will check the flow of the radiator. For the side chamber radiator, if the hose collapses, the blockage is internal (engine) for the other style it more than likely could be the radiator (more testing and water will be needed) With everything disconnected and feeding water to the cooling system you will be able to see the thermostat cycle open and closed and be able to measure the temp it opens at with an isolated thermometer. What do you think....?
