#22 | |
Re: TBI Conversion on a 400 SB w/4spd...
Manufacturer's Part Number 12-268-4 Cam Style Hydraulic flat tappet Basic Operating RPM Range 1,800-5,800 Duration at 050 inch Lift 224 int./230 exh. Advertised Duration 268 int./280 exh. Valve Lift with Factory Rocker Arm Ratio 0.479 int./0.480 exh. Lobe Separation (degrees) 114 Computer-Controlled Compatible Yes Grind Number CS XE268H-14 //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
| Bookmarks |
