Old 05-12-2011, 03:36 PM   #1
drsergio
drsergio's Avatar
69 GMC radiator question
Took the truck for a ride and notice after few minutes on the parking lot , that was water leaking from the radiator ( the hose conected to the top )
open the cap and really the water is there,,,maybe 2 inches under the cap
Any idea?
The engine did not over heat
is that normal ?
ty
drsergio is offline   Reply With Quote
Old 05-12-2011, 04:20 PM   #2
TheSeeker
Re: 69 GMC radiator question
If its leaking, its not normal. Id replace the radiator hose and see if that doesnt help. It may not be overheating now, but you dont want to be stuck in traffic on a hot day with a blown hose or water pump.
TheSeeker is offline   Reply With Quote
Old 05-12-2011, 04:23 PM   #3
geezer#99
geezer#99's Avatar
That's normal. It finds it's own level. Enough for expansion.
Old 05-12-2011, 04:34 PM   #4
drsergio
drsergio's Avatar
well the radiators look fine
not even getting hot,,,
Old 05-12-2011, 04:42 PM   #5
Clyde65
Clyde65's Avatar
it is normal, the fluid only needs to cover +1" over the coils in most cases. a little expansion room is good. also condensation will come out of the overflow tube if real cold or hot outside.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-12-2011, 05:36 PM   #6
drsergio
drsergio's Avatar
Thank you
was running dripping for maybe 5 minutes,,,enough to make a mark on the driveway
could say a good beer cup
will keep eye on
Old 05-12-2011, 05:40 PM   #7
geezer#99
geezer#99's Avatar
When it finally stops dripping check and see what the level is. Keep it full to that point.
Old 05-12-2011, 08:28 PM   #8
JimKshortstep4x4
Good looking GMC!
If it bothers you it is easy enough to install an overflow tank. As has been mentioned it is normal for the radiator to spit some fluid out if it is over filled.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
