What shift linkage & bracket will fit on my '68 with a 700r4?
Will a TH350 or TH400 bracket set-up work from the '67-72 years? Thanks, Mike
7th year of '68 C-10 LWB Rebuild in progress. Drivetrain done. Frame stripped, painted & rebuilt. Body/paint next. '18 Yukon '04 Sierra 4X4 ‘77 Chevy C-20 Camper Special ‘68 C-10 Shopping for a 69-72 4x4 Blazer or Jimmy |
Mike
Are you hooking up to the colum ?Also you will need a tv cable bracket.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
700r4 column linkage
The 700r4 is in and running. Looking for the column linkage. I'm using a rigged '75 linkage and bracket that allows me to get from Park to Drive. Just can'tget down to 1st, plus it's pretty sloppy.
I've also heard about some folks using a Lokar kit. Anyone use these? Any advice would help. Mike
Recovering 67-72 Addict
![]() Join Date: Oct 2000
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
the units breeh mentioned work great I have used several of them and never had a problem
Mike
I don't have that set-up.Yet.Have either of you used the indicator lens they offer for the overdrive?
2.5/4 on 20's
I have the Lokar and it works great. Mine has very smooth operation.
62 C/10 SWB. Currently in ground up resto. Big back window cab, V8, auto. My wife's grandfather's truck. 1965 Mustang Vert - Shelby Clone 2005 Dodge SRT-10 My Old 72 SWB |
trucks72
If you are using a factory column. You will never be able to go completly into 1st gear.
14.1 @ 96MPH
I've heard a few things regarding 700R4's, first gear, and stock columns. Some say it can't be done period; some say it will work if you adjust it properly; and some say you can get the detent but the 700R4 will still shift out of first whenever it damn well pleases (seems odd
![]() I think I've got mine adjusted, but I still can't get it into first. ![]() (FWIW, I'm using the linkage almost exactly as it was on the THM400 it replaced.)
Project1970 - LS1 Swap Complete! ![]() |
Mike
I think if I was worried about going into and holding first,I would use a floor shifter.
![]() Join Date: Jul 2000
I am using stock shift linkage and tilt column. I am able to get all gears with no problem.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
