Old 05-13-2011, 10:26 AM   #1
dave2953
Dave's not here, man
dave2953's Avatar
What did you screw up today?
The thread regarding "what you got done today" was quite popular. I know we all screw up stuff from time to time. As such, I was wondering what you screwed up and had to fix. In my infinite wisdom, I put the flywheel on backwards and didn't realize it until I had the motor/tranny installed and tried to spin the torque converter to get it bolted to the flywheel. Needless to say, I wasn't a happy camper. Shortly after that I installed my thermostat housing, only to realize I forgot to install the thermostat. So what did you screw up?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 05-13-2011, 10:55 AM   #2
shaneschevys
Its always something!
shaneschevys's Avatar
Re: What did you screw up today?
Nothing yet. But it's still early!
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 05-13-2011, 10:57 AM   #3
darush01
Well i wrecked my 83 on monday and today havent done anything to screw up
darush01 is offline   Reply With Quote
Old 05-13-2011, 11:19 AM   #4
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
i screwed up my elbow today.....lingering problem. and im a sissy, i did it putting my daughters bike together......
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 05-13-2011, 11:23 AM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
I figured out you can't put an oil pump drive shaft with the pinned on metal collar through the top...... Looks like I get to pull the boat engine... Again.
I'm in the process of moving so all of my toys and tools are in a storage building, just to make things more interesting.
brad_man_72 is offline   Reply With Quote
Old 05-13-2011, 12:14 PM   #6
Dunenutt
Newbee
Dunenutt's Avatar
You are not alone! But you will only do it once!
Dunenutt is offline   Reply With Quote
Old 05-13-2011, 12:48 PM   #7
chopnchaneled
chopnchaneled's Avatar
Which time ! and its only noon here on friday the 13th!!!!!!
chopnchaneled is offline   Reply With Quote
Old 05-13-2011, 12:55 PM   #8
68 SHORT-STEP'N
SLOW POKE
68 SHORT-STEP'N's Avatar
Well ... it all started when I woke up ...
68 SHORT-BED-STEP-SIDE
piece by piece ,
day by day ,
I will restore this truck ,
before the 100th anniversary !!!
68 SHORT-STEP'N is offline   Reply With Quote
Old 05-13-2011, 02:15 PM   #9
70cst
70cst's Avatar
Nothing...I'm leaving that opportunity to fine69
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-13-2011, 02:59 PM   #10
Clyde65
Clyde65's Avatar
Why? What did you hear?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-13-2011, 03:57 PM   #11
50bomb
50bomb's Avatar
hahaaa You beat me to it....Story of my Life
50bomb is offline   Reply With Quote
Old 05-13-2011, 05:17 PM   #12
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
i will report bacl im fixin' to change my oil lol
John
1999 Toyota Tacoma 4x4
Old 05-13-2011, 05:51 PM   #13
6772owner
Gearhead
6772owner's Avatar
Well I didnt do it today, but recently I tried to install my new ECE trans crossmember, after cutting old the perfectly functioning one, to find out the trans didnt line up with the crossmember and my exhaust wouldnt go back in! (After pulling the entire exhaust from the headers back)
Now I have to have the new crossmember welded on and the exhaust redone... all because I "wanted" the new crossmember.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 05-13-2011, 06:31 PM   #14
68gmsee
Active Member
68gmsee's Avatar
Tried to see if I could put seals in a power steering gearbox I had. When I removed the input shaft worm gear, all the bearings fell out and haven't figured out how to re-install. Basically, it's a mess.
68gmsee is offline   Reply With Quote
Old 05-13-2011, 06:38 PM   #15
cadillacart
1972 C/20
cadillacart's Avatar
I did it a while ago, but I cut 2 full coils off of my front springs. I currently have about 1" of travel before the sway bar bushings act as my new bump stops. Someday I'll have money to have drop spindles.
My Gallery
1972 C/20 402
Gramp's Truck
cadillacart is offline   Reply With Quote
Old 05-13-2011, 07:12 PM   #16
A.T. RockDriller
A.T. RockDriller's Avatar
GMSeeeeee,
I think you will find it a cinch to reassemble that pump if you clean the race and brgs with solvent or brake cleaner and then gob some litheum lube into the race...the bearings will then stick nicely in place......and might even stay there 'till you get it reassembled.....
Maybe.
Good luck.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 05-13-2011, 09:21 PM   #17
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by A.T. RockDriller View Post
GMSeeeeee,
Maybe.
Good luck.
Good idea. It's a spare one that I had and trying to learn how these d@mn things work. They look simple enough except for those little bearings. I'll try the grease. Thanx.
Old 05-13-2011, 11:44 PM   #18
Hubscrub
Cruzin
Hubscrub's Avatar
I replaced my alternator on my 97 yesturday, must have knocked one of the air conditioner lines out of it's clip and the belt has eat a gash in it and all my 134 is gone by by
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-14-2011, 07:56 AM   #19
67 chevy heaven
Well,
The latest screw up or mine involved me thinking that I had to change the stock rear end cover bolts out with stainless steel ones. I had just gotten the whole rear end rebuilt,( posi, gears, all brakes and all hardware, not to mention all of the powder coating) of the entire thing. Well as I was tightening down the third stainless steel bolt the head snapped off. I center punched the broken SS bolt went to drill it out and attempt to use an easy-out on it. The bit would just follow one side of the broken hope no matter how much I tried to keep it centered. In the end I had a friend help me clean up the hole that I had made and retap it.
Boy I felt soooooo defeated. After all of the major rebuild going well and to have the very minor part kick my read end!!!( LOL, no pun intended)
67 chevy heaven is offline   Reply With Quote
Old 05-14-2011, 04:32 PM   #20
The Youngen
I didnt do it today but so far, my screws up have been
a. not having it done by now.
b. using a backhoe to lift up the front end with a chain wrapped around the frame. The hoe than wacked the radiator.
The Youngen is offline   Reply With Quote
Old 05-14-2011, 10:05 PM   #21
6 Door King
Did it last week, but the fix happened today. After pulling the intake and distributor, I replaced the parts and proceeded to drop the HEI cap into the radiator, knocking three tubes out of commission. Turns out it saved me a lot of trouble later, the thing looked like swiss cheese when I pulled it out...
6 Door King is offline   Reply With Quote
Old 05-15-2011, 12:15 AM   #22
crazy longhorn
Fabricate till you "puke"
I screwed up the dishes today Guess I didnt load them properly? O well, that old woman has been trying to "domesticate" this old man for 30 yrs. Sorry babe, I know how to load the pistons /pins,rods, & even the crankshaft in the dishwasher(PROPERLY) crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-15-2011, 10:06 AM   #23
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE=brad_man_72;4677849]I figured out you can't put an oil pump drive shaft with the pinned on metal collar through the top......
... what???
Tom Vogel is offline   Reply With Quote
Old 05-15-2011, 11:02 AM   #24
72BLUZ
72BLUZ's Avatar
some how i got the tool box on my gmc shut and could not open it for several days. finally used pry bar and with little pressure it opened. then spent hour trying to adjust the latch
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 05-15-2011, 01:50 PM   #25
Gray
I did a good one today. I was replacing a windshield in my 72 with one from LMC. They said to install the gasket on the pinchweld, then install the glass. It seemed correct as I've installed several windshields in my 77 since I bought it new, and that's the way I've always done it. Well, I cracked it trying to get it in. Luckly a local glass company had one in stock and they're open till noon on Sunday. It was also over a hundred dollars cheaper than LMC too. I installed it with the gasket on the glass, but now I'm having trouble getting the chrome insert in the rubber. Anyone know a trick to getting the chrome in?
Gray is offline   Reply With Quote
