Old 05-13-2011, 06:42 PM   #1
1971ls1longbed
1971ls1longbed's Avatar
Lowering my 71 LWB
I want to use a 4/6 drop on my 71 lwb and i have a big block. I cant afford air suspension so im going to do it with springs and spindles ect. . Can you guys please tell me what the best way to do this is. I was going to use 2" drop spindles, 2" springs in the front and 2" blocks and 4" springs in the rear with a "c" notch. Does this sound right?
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted
1997 C3500 DRW Ext cab. 454, 4L80E daily driver
1971ls1longbed is offline   Reply With Quote
Old 05-13-2011, 10:28 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Lowering my 71 LWB
I would go more spring, less block out back if you're running 15" wheels. Pick the drop coil you want and tweak it with blocks, if necessary. Otherwise, your ideas check good
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-13-2011, 10:45 PM   #3
1971ls1longbed
I am going to be running 17" wheels, longer panhard bar, big sway bars and shock relocation kit
Old 05-14-2011, 08:58 AM   #4
SCOTI
SCOTI's Avatar
The front drop sounds good. I believe the spindle drops are 2.5" or 3" if using standard drop spindles, & 2" if using CPP's modular drop spindle. Just making sure you're aware of the variations.
The rear sounds good as well. You should be fine w/the 2" block if using 17's. Have you checked out board members/vendors No Limit & their JT build thread? They offer great insight & came up w/some nice rear shock/Panhard bar stuff....
http://67-72chevytrucks.com/vboard/s...d.php?t=436621
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
