Old 05-16-2011, 11:32 PM   #226
67shortie
Green club
67shortie's Avatar
Re: Shreck's 6.0 build
Also, took the truck on a 300 mile trip this weekend. Ran perfect in any condition, and without exact math averaged about 17MPG on 87 octane +/- a .5 margin.
That number is mostly freeway I would imagine 85% to 15% local driving. I am happy, comparing to what it used before I am 5MPG positive average so far. Quite nice, and driveability is much improved. Freeway cruising is very good, cruise along with traffic with little effort and has lots of power in reserve for passing and/or just showing off
That's my experiences so far, and for those sitting on the fence please don't it's worth it.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 05-17-2011, 12:16 AM   #227
SCOTI
SCOTI's Avatar
Awesome job!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-17-2011, 11:16 AM   #228
thor
thor's Avatar
Sounds like an awesome upgrade! And thanks for the kickdown linkage pics too!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 05-17-2011, 03:37 PM   #229
harnalien
TruckincrazY
harnalien's Avatar
Originally Posted by 67shortie View Post
Don't know if this is what you needed but these are pics of the throttle cable bracket and the BTO hookup.
That's exactly what I needed. Thanks a lot!!
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 10-19-2011, 12:51 PM   #230
gringoloco
A guy with a truck
gringoloco's Avatar
Digging up the dead, just to say: Very nice work! If I did it, it would be just like this...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-19-2011, 07:35 PM   #231
jbice70gmc
jbice70gmc's Avatar
Did you happen to notice how many RPMs you run at say 70 MPH.
1969 GMC SWB Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=486320
jbice70gmc is offline   Reply With Quote
Old 10-19-2011, 10:36 PM   #232
mcbassin
Still Learning
mcbassin's Avatar
Haven't seen an update here in a while. What's up?
Old 01-22-2015, 05:24 AM   #233
RUN GMC
RUN GMC's Avatar
Nice build thanks for the link from the G body forum page.....................
RUN GMC is offline   Reply With Quote
Old 05-09-2016, 07:33 PM   #234
SKT
SKT's Avatar
Any updates or anything new w/ this one?
How's the 6.0 holding up?
SKT is offline   Reply With Quote
Old 05-24-2021, 01:33 PM   #235
Duck1
Umm, maybe
Not much to update, still waiting on parts. I did get my power brakes hooked up via a factory fitting that goes into the rear of the truck manifold and from there it's simple routing of a 3/8 hose to the booster.
It still wants to start and run but with no fuel pressure it does very shortly but it does run. Oil is in, filter on but I cannot tell what kind of oil pressure I have without my guage hooked up but by this afternoon my Summit order should be here. It is circulating, the oil has a pink hue to it from the assy lube on the bearings.
I hope to get in everything I need by tomorrow so I can continue, I am kind of worried about the exhaust, the SS manifolds may not working referencing to USMC's build. We will see.
fu: I had a guy pay $50 to change that hose from 3/8" to 11/32" hose, because the CCP/CPP instructions called for it. 3/8" = 12/32". 1 mm
Duck1 is offline   Reply With Quote
