05-12-2011, 02:02 AM | #1 |
Solid axle swap questions....
I am thinking about doing a SAS swap on my 90 k1500. the trucks front diff is toast, and the rear axle is junk. I have a line on a 83 k10, and I would be using the stock 10 bolt front and rear, and t case. my questions come up when trying to figure out the steering linkage. Some have suggested its a "plug and play" setup, while others say that I have to go with crossover steering. I dont have the cash to go shell out for the correct knuckle, but I did see an alternative that looks like it would work....
What do you guys think? Does this look right? Does it look safe? (this pic is off a Jeep, and not mine, I just wanted to use it as a reference)
2017 Tahoe Premier - Daily '99 Silverado 2500 Wife's whip- 2020 Equinox Premier |
05-12-2011, 08:23 AM | #2 |
Re: Solid axle swap questions....
If your not going crazy with the lift, that setup would work.
If you google low lift solid axle pirate4x4, there is a thread that shows steering setup on a low lift SAS, should give you some ideas.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
05-12-2011, 06:53 PM | #3 |
Local Redneck Authority
I don't like the look of a single shear bolt with a steering responsibility. If you could weld on the knuckle to have a double shear it wouldn't be so bad. Ball joints are much more robust and hardened than even a grade 8 bolt.
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
05-12-2011, 10:28 PM | #4 | |
You can get a flat top Chevy Dana 44 knuckle in junk yards for cheap. Have a flat top arm put on it and you're done. It'll interchange between any of the 69-87(91) solid axle trucks. For a few hundred dollars and you'd be set. Just to give you reference, I just sold a Reid Racing knuckle with all new ball joints, ARP studs and cones, a WFO Concepts arm, and two tie rod ends for $400. They were brand new, I couldn't use them since I only have Dana 60s now. If you shop around, you can find some smokin' deal on the RIGHT parts. |
05-13-2011, 02:48 AM | #5 |
That is what I kinda figured. I thought that the connection looked cheap and cheesy, but wanted some input as to why. I will have to do some looking around for the right parts.
How do I tell which one is which, in regards to the knuckle? I would assume the flat top knuckle would be just that, but what do they look like? I guess I am just looking for a pic of the correct part.... Thanks guys for all your help so far! Posted via Mobile Device
05-13-2011, 08:22 AM | #6 |
Hmm didn't even pay attention to the single shear, thought you meant the tierod placement.
Another method is to use the stabilizer hole to mount the draglink......
05-14-2011, 12:57 AM | #7 | |
thanks everyone for the help. at the very least, I can get it to the roller stage, to move around the yard.
05-18-2011, 12:31 AM | #8 |
Chevys Kick A$$
So your going to use the t-case from the donor truck then? Like stated above I don't like that lazy setup either. Yes it would work is it safe no would I say use it no!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
