Old 05-06-2011, 04:49 AM   #1
kikkegek
kikkegek's Avatar
SBC350 - 160F while driving, 200 at traffic light
I wanna check something with you guys.
I have a 195F thermostat in my cooling system. but at a traffic light the engine will warm up to 200F and then the electric fan will kick in and cool it down to 185F and shut off.
but as soon as I start driving, both in town and highway, the engine is cooled down to 160F...even on long drives...
how can this be? and isnt 160F far too cool for a small block? I thought it should be at 190-200F?
I checked the thermostat and it opens and closes at about 185-190F.
see this video (sound is crappy, sorry!).
So the thermostat seems fine. but if this doesnt open untill 185F, why does my engine run so cool?
kikkegek is offline   Reply With Quote
Old 05-06-2011, 10:44 PM   #2
russgt
russgt's Avatar
Re: SBC350 - 160F while driving, 200 at traffic light
What are you running for a radiator?
70 stepside
76 blazer
86 Sierra Classic
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 05-07-2011, 09:11 AM   #3
kikkegek
kikkegek's Avatar
I guess the original one that came from factory. three rows thick.
here you can find all the pictures from my car:
http://picasaweb.google.com/jochenz/...6K20Silverado#
Old 05-07-2011, 10:57 AM   #4
russgt
russgt's Avatar
It looks like you installed a flex fan, are you still using it? I would suspect that the extra air flow from the flex fan at speed is causing the extra (160 degree) cool down while driving. A clutch fan would disengauge at speed but the flex fan is still pulling. At low engine RPM (while sitting in traffic) you do not have enough coolant flow/air flow to keep the engine from warming up (200-210 degrees) the good new though is that your electric fans are working correctly and can cool down the engine.
70 stepside
76 blazer
86 Sierra Classic
71 Nova SS
Old 05-07-2011, 03:42 PM   #5
kikkegek
kikkegek's Avatar
the flexfan was replaced by the electric fan. The flexfan kepot the engine at 150F all the time (too cold)!
now with the electric fan the temp rises to 200-210F at traffic light but while driving the electric fan is off, but the engine still cools down to 160F....and the e-fan is off!
Old 05-07-2011, 10:47 PM   #6
Psycho71
Psycho71's Avatar
You could try blocking a portion of the radiator. That would effectively remove cooling capacity from the radiator. Just don't get too aggressive. I have an Aluminum 3 row in my burb w/a 180*stat, it runs a constant 180-185*. My '71 has an aluminum 2row w/a 180* stat and two electric fans. It runs 180 at idle all day long, and gets up to about 190* on the hwy. I'm thinking the shrouded electric fans actually inhibit airflow at hwy speeds. It'll get a 3row in the future. I know 190 is not bad, and that's why I have yet to change anything. But I too expect one to run really close to the temp range of stat I have in the water neck.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 05-07-2011, 11:07 PM   #7
78 Chevyrado
How can you tell what the temp is when your going down the road? what are you using to measure temp. The dash gauge is worthless for telling actual temp numbers, and the cap in the radiator can be off by as much as 10-15 degrees difference between the radiator and engine block, especially if the T-stat is closing. The only way to know the engines real temp, is to measure directly from the block, cylinder head, or intake manifold BELOW the T-stat.
When my intake reads 198 in my truck, at the radiator it reads about 182.
If you're engine is truly cooling below 190-195 degrees, the T-stat is what it is, unless you have a bypass somewhere besides the heater hoses.
If you are going by the radiator cap for temps, double check it against a known good thermometer, just in case. If you can get your hands on one, try to come up with an infrared thermometer. They are awesome.
Are you using the air conditioner? depending on how you hooked it up, the AC may make the fans run when it does. My truck runs the coolest at a red light, with the AC on.
78 Chevyrado is offline   Reply With Quote
Old 05-08-2011, 05:13 AM   #8
tobiahr
tobiahr's Avatar
what spark plugs are you using? using to low of a heat range plug can have the same type of effect although i've never seen something this extreme.
tobiahr is offline   Reply With Quote
Old 05-08-2011, 11:29 AM   #9
kikkegek
kikkegek's Avatar
I keep forgetting to do a test like that, to check of the rad is cooling,although the engine temp is below thermostat temperature.
Old 05-08-2011, 12:51 PM   #10
kikkegek
kikkegek's Avatar
I use the dash gauge for temp readings. I know this one is right. The sensor sits in the block on the driver side between the spark plugs.
The temp it shows is correct, because as soon as it hits 200F, my electric fan kicks in. The thermostat of the electric fan kick in at 200F and off at 185F. The temp sensor of the fan sits in the thermostat housing.
I recently checked the thermostat, cooked it and it opens and closes at about 185F. A little early for a 195F thermostat, but close enough.
I do have a little bypass in my system, its the evaporator of my LPG system. But I already investigated that and its supposed to use very little heat as LPG evaporates already at room temperature.
So I am still in the dark why my car cools down to 160F while driving and then heats up to 200F at the traffic light. Seems like it is getting cooling through the radiator, but it shouldn't, because the thermostat should be closed.
Old 05-08-2011, 12:53 PM   #11
kikkegek
kikkegek's Avatar
I have absolutely no clue. I need to check that. But LPG already burns warmer then regular fuel. So I am not looking in this direction.
Old 05-10-2011, 10:30 PM   #12
RaVeNlI666
Not to hijack your thread but I am having more or less the same problem with my 79 Blazer. I have an auto meter water temp gauge and it will get up to 200 at a stop light, and even if I am going 25 mph it will drop to 160, if i am going down the freeway it will go as low as 140. Probe is before t-stat on intake. Dual elect fans on a 383 stroker and a rad from an 82 chevy PU. only thing I changed on mine was the intake. went from a dual plane to an air gap......
RaVeNlI666 is offline   Reply With Quote
Old 05-11-2011, 02:47 AM   #13
kikkegek
kikkegek's Avatar
dont worry, as long as your having the same problem and hopefully we find some solution here.
I have given up for now.
I had a bypass over the passenger side of the rad, because my evaporator of the LPG system is connected in parallel to my heater core. But I moved the return connection from my heater core to the waterpump.
So now coolant can only flow over the rad if the stat opens. I checked my stat and it opens at about 85C (185F) and its a 195F stat. So I am sure that is not causing the cooling when I start driving.
short analysis. Engine is at traffic light heats up from no cooling to 200-210F and the electric fans kick in. as soon as the tempguage hits 185F the fans turn off...so the gauge is working fine. when I start driving with 200F, the waterpump speeds up, because of the higher rpm, the read cools the water down to below 185F and the stat should close. Now the coolant can only flow through my engine and heater core (wich is OFF) and through my evaporator, but this takes only very little heat I heard. LPG evaporates very easily. so the evaporrrator and the heater core arent delivering any cooling.
So I wonder....what is cooling the engine OR
right now at the traffic light my temp gauge moves between 200 and 185 and during driving it is at the yellow line. for now I have given up...
Maybe the lower parts of the temp gauge isnt accurate and fooling me into a cold engine...
Old 05-11-2011, 03:52 PM   #14
jjmorrse
You can drill holes in your shroud and install rubber flappers that open at speed. Spal makes some.
jjmorrse
86 C30 crewcab big dooley. 454- 400
jjmorrse is offline   Reply With Quote
Old 05-18-2011, 04:42 PM   #15
kikkegek
kikkegek's Avatar
Something else I noticed is that the scale on the temperature gauge on the dash is not lineair:
the left side runs from 100 to 210. A difference of 110 degrees.
the right side runs from 210 to 260. A difference of only 50 degrees.
So who know what the number is for the points in between on the left and right side of the 210F?
I know my fan turns on then the gauge is at about what I guess is 200F and the fan turns of when it is at the position in the picture below. It turns off at 185F...
does anybody know the scale of these gauges. What is the value of the points left and right of the 210F?
Old 05-18-2011, 11:14 PM   #16
68Timber
I know the pieces fit
68Timber's Avatar
I'd guess 155 and 235.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
